Horn Not working. Steering column changed to one with cruise control.
#31
Stay on the right side diagram. See that big blue square in the middle that says "Horn switch, set, accel, coast, and resume"? That's the steering wheel part that turns. That has the horn button and the cruise switches in it.
Look around the outside edge of the blue box. Each connection says "brush". That's the ring/brush sliding contact in the steering wheel. You have had it apart, you should recognize what I am describing correct?
The blue wire should go up to the brush or the contact trace(I have forgotten if the brush is on the wheel or in the column)
#32
I have dark blue and yellow/maybe dashed something wires going to these two springs. Not sure if thats the piece i'm looking for. Gonna do a little research right now.
#34
Stop, wait a minute, hold on. The cruise control right side diagram shows 3 brushes. And the wires should be darkblue, blue/black and black.
Your picture only has two brushes, and you said it has a yellow/lightblue and one other wire. That matches the left side diagram, the one with no cruise. You have a mess going on here. That part in the picture is for a non-cruise truck while your truck has cruise. Someone verify what I am seeing and see if I am mixed up or not.
#35
Im going to use a scrap piece of wire to ground the brush wires to the steering shaft.
Also Im adding a cruise control servo from pull a part. Looks like thats the only other thing missing from all this.
#36
#37
#38
So guess what. After a little more trouble shoothing. I changed the horn relay. Yep. Thats what got it working. Auto zone had it to me next day.
Can someone help me clearfy a couple of things. I used a test lead to see if the blue wire had power at the horn switch. I didnt. Also i jumped the power wire and the wire going out to the horn together. Essentially by passing the relay and the horn worked. With that i decided to replce the relay. Tell me what you think. Good method or just lucky?
#40
#41
As I think about it, my problem wasn't the same. I had the cruise system installed, so when the horn worked when the key was off and not on I discovered it was using the cruise as a ground. But, when the cruise...... oh, wait.
The trucks with cruise also have a relay, which the trucks w/o cruise don't have. If you look at the schematic the horn button on the non-cruise models connects power to the horn. But on the cruise models it grounds the coil side of the relay. Altogether different.
You may be able to just add the relay - if you can find one. Or, make a Bosch relay do the job.
Dunno about 1980/86's, but 1978/79 F100/350's, Bronco's and Econolines with Speed Control, the horn relay plugs into the Speed Control's amplifier.
#42
My truck actually did have all the speed control parts except the servo.
#43
#44
I found a servro from a 302 EFI bronco....the trottle cable doesn't fit right. It's on the back burner for now.
86f150step
09-23-2013 07:21 PM
