Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
f53 rv with 460 efi won't start
Old 01-15-2015, 07:37 PM
groker's Avatar
groker
groker is offline
I've had this RV for about 4 years now, and aside from working out bugs at the beginning, it has been reliable. The only wierd thing I've noticed is that once it is warmed up I have to give it a little gas when I restart it. Then the rmps fluctuate between 800 and a 1000 for about 15 seconds and then settles down to a nice idle.
Two days ago I was going about 65 when the engine died. I put it into neutral and tried to start it as it slowly ground to a halt. I haven't been able to start it yet and have been dry camping on the side of I75. It turns fine but doesn't catch.
First thing I did was checked the fluids. Oil was fine. The antifreeze is brownish. Then I checked the dog house.... I guess a squirel thought it would be a good place to stash its nuts. I imagine he was pretty disapointed when his stash rolled down the road!
Anyhow, here is a list of what I've done so far (in order)....
-replaced fuel filter (overdue anyway)
-replaced fuel pump relay
-replaced pmc power relay
-tested injectors with mechanics stethiscope. All of them double clicked at regular intervals.
-tested fuel pressure. 40 psi while cranking
-replaced map sensor
-replaced coil
-tested cylinder compression on passenger side. Between 85 and 110 lbs/in2
-all plugs on the passenger side had spark and smelled of gas
-replaced igition module
After I replaced the ignition module, the battery was too dead to turn it over. It's over at O'Reillies niw charging. Hopefully it will start right up, but I would appriciate any advise in case it doesn't. As much as I love the sound of traffic and the semi turbulance rocking me gently to sleep, I'ld like to get back on the road.
Here is my todo list for tomorrow on the off chance it doesn't start....
-add redundant ground to battery
-remove fuel rail to check the spray pattern of the injectors
-remove the ecm and check for leaky capacitors and broken solders.
Right now I suspect the ecm but I hope it's OK. Thanks in advance for any advice.
Old 01-15-2015, 09:22 PM
groker's Avatar
groker
groker is offline
still not starting
I put in a newly charged battery and it still won't start. However, now it turns over realy slow and bogs down the electrical system. Now I suspect the piston bearings or journal bearings. I'm taking it into the shop tomorrow and will see what they say.
Old 01-16-2015, 01:02 PM
awhtx's Avatar
awhtx
awhtx is offline
Maybe the starter is going bad and is drawing too many amps when cranking. If all of the electrical "juice" is going to the starter there's none left to fire the ignition.
Old 01-16-2015, 07:04 PM
Tom A's Avatar
Tom A
Tom A is offline
Pull the vacuum hose off the fuel pressure regulator and turn on the key. If it shoots fuel out of the regulator, it needs to be replaced. I had a Bronco once that had the same symptoms and this was the problem. It actually hydrolocked the engine with gasoline.
Old 01-18-2015, 11:22 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
Heck since it should not a have a Mass air flow sensor. If its cranking a normal speed give it a small shot of starting fluid. THis should tell you if you have spark at the plugs.
IBJanky
1983 - 2012 Ranger & B-Series
49
10-31-2021 09:10 AM
rf15eagle
33
10-22-2014 07:51 PM
njstevens
03-04-2013 11:21 PM
gilllawn
01-16-2006 01:38 PM
togoffrd
1978 - 1996 Big Bronco
04-21-2005 01:53 PM
Quick Reply: f53 rv with 460 efi won't start
