Looking for some assistance in what years the bed of my truck would span. The truck is 2002 F250 Sd Xlt 5.4 short box 6ft 6 I believe. In desperate need as the cross members are seriously rusted out to the point where the box has dropped inch and a half at the cab. Thanks in advance.
Good to know I'm finding it harder and harder to find parts here either discontinued by ford and the F250 when they do hit the scrap yards around here (Northern Ontario ) they are so wrote off there's usally nothing left.
I found a replacement bed for mine on craigslist. It took a while and I was really deating weather or not to build a flat bed but found one that is the same color as my truck other then a black stripe on the bottom
Same issues and thoughts here although flat bed isn't very practical for my needs to much work gear lol. Been on a hunt for 5 months from scrape yards to farm yards.
The body lines are the same from 1999 to 2015 it's the wheel well flair that is different 2011 thru 2015 and there is a crease around the flair,also the gas filler tube may need to be longer and the gas door is square.Some put Bushwacker flairs on all four wheel wells if they put the new box on.
Ok now would that also be the same span of years 99-2010?
Once again thanks for all the valuable information gentlemen.
Yes F-250 and 350 short beds are the same 99 thru 2010 as well as the 2011 thru 2015 with the newer whee wells. Short bed is a short bed with Super Dutys
