Anti Gelling additive
Living in the desert I don't usually have to worry about this, but I am going to be spending some time in the high country where lows are expected as low as zero and highs below freezing. My batteries are strong and fairly recent. My GPs and relay are all good. My oil is Rotella 15/40. I use Stanadyne Performance Formula but it doesn't really say anything about anti gelling, so what should I use? Also, is the 15/40 going to give me trouble cranking at zero degrees after sitting all night? She's always been a quick starter, no more than 6 or 8 rolls and she fires right off.
I'm in central PA so not sub zero real often but I have dealt with more than a couple of them. If you buy your fuel at a fairly reputable station in a cold area they will be selling winter diesel which contains anti-gel additives. But as far as additional additives or for the fuel you buy before leaving the desert, power service is a good one. In fact my local station sells power service diesel fuel. If you want the extra peace of mind there is a product made by power service called diesel 911 that degels fuel that has already be gelled.
Amazon.com: Power Service 1080-06 +Cetane Boost Diesel Fuel Supplement Anti-Freezer - 80 oz.: Automotive
This is what I use> Truck runs quieter when that stiff is in for some reason.
