Back up cameras
#31
Look at the American International kit - problem is I think they quit making them very recently. I'm sure places still have them in stock.
#33
I used Metra 95-5817 on mine and while it does slide into place with the trim installed, it locks in so solidly you cannot remove it from the trim again unless you pull the entire thing off and unscrew the side plates off the radio first.
Also note you will need to modify that trim panel. There is a lip all the way around the opening and you need to cut off THE TOP AND BOTTOM ONLY.
Crappy installed pic
#34
Thanks for the pic! I have seen these and read about them and I do like the rolled edges but to me it looks as though the rolled edges have a "missing" section at the top? Can you get a better pic of the filler pieces on the sides of the radio and how they fit the dash?
I don't mind having to pull the dash piece out to get the radio out. It is very easy to do.
Thanks everyone for the posts!
#37
#38
#39
this is the 12$ metra kit i used,
http://www.amazon.com/gp/product/B0026CJ8F8/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1`
#40
Ok I just went through all of this. The Metra 95-5817 is the kit with the rolled edges. This is the kit they recommend when you buy a double din for our units. But the Metra 95- 5818 is the one with the nice flush edges witch I prefer. I just ordered a new deck and both kits because I wasn't sure if the 95-5818 would work in a excursion or not. I think they recommend it for a 99-03 superduty. Probably the same I would think. Good luck.
firstrider
10-19-2016 07:16 AM
carid
11-13-2015 08:08 AM
