Motor confusion. Need opinions
I have a 66 F350 4spd 2WD.
Serial number indicates "C" for 330MD. (F35YCXXXXXX)
Block casting is C6ME whick could be a 330MD.
Air cleaner has 352 271 HP on it. (partially worn off)
Block has 352 cast into it (yes I know most do)
What is IT?
I am getting a 390 block and rotating assembly hopefully this weekend. My plan is to build a 390 for it with EDEL aluminum heads. Main question is will I have issues bolting the NP435 to it or any other issues. I know the front motor mount bolts to the timing cover and a single attacment to the front frame and I may have to use the original timing cover.
What is IT?
VIN engine code is Y = 352 2V / C is the assembly plant code: Oakville Ontario Canada Truck Assembly Plant.
No 352 installed in a car or truck came with 271 HP.
The only Ford with 271 HP was the hipo 289 installed in some cars (VIN code K).
1965/67 F100/350 352 air cleaner decal: 208 HP
Stamped on the 3rd line of the Warranty Plate w/a 352: 172 net HP @ 4,000 RPM
All 1953/78 F350's are 2WD, 1979 was the first year that F350's were available with 4WD
1965 F100/250 4WD - 1965/66 F350 - 1966 F250 4WD use the same engine mounting system (upper pic).
1965/66 F100/250 2WD - 1966 F100 4WD - 1967/76 F100/350 use a different engine mounting system (lower pic).
The FE bell housings are specific to each system.
1973/78 F350's made exclusively for U-Haul came with this engine.
It's possibly that it was swapped in, but I doubt that also.
I edited in a parts catalog pic inre to engine mounts in post 2.
MNTBUGGY
02-17-2019 08:43 PM
pitdog0938
32
04-20-2015 12:26 PM
