65 - VIN
Old Sep 14, 2010 | 05:15 PM
46490's Avatar
46490
65 - VIN
I am buying a 65 F100 and I would like my vin decoded if possible - F11GR649755
WB - 120
MODEL - F110
BODY - D81
TRANS - N
AXEL - 08
I UNDERSTAND THAT I HAVE A 120" WHEEL BASE, BUT I DON'T KNOW ABOUT THE OTHER NUMBERS. I DO HAVE A TWO SPEED TRANSFER CASE AND A 4 SPEED TRANNY. THE MOTOR IS A 390 WITH A 352 STAMPED ON THE FRONT OF THE BLOCK (RIGHT SIDE LOOKING TOWARDS THE REAR), 4 BARREL CARB WITH A SMALL HIGH RISE MANIFOLD AND 3" DUAL EXHAUST. THE BODY AND FRAME ARE RUST FREE AND STRAIGHT. NO POWER ANYTHING - JUST A DEPENDABLE DAILY DRIVER - I HOPE.
Old Sep 14, 2010 | 08:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 46490
I am buying a 65 F100 and I would like my vin decoded if possible - F11G R649755
WB - 120
MODEL - F110
BODY - D81
TRANS - N
AXLE - 08
Welcome to FTE
F11 = F100 4WD
G = ? No such VIN engine code. 1965 F100/250 2WD/4WD & F350: B = 300 I-6 / D = 352 2V / J = 240 1V I-6.
R = San Jose CA Assembly Plant.
649755 = 1965, assembled February 1965.
120" Wheelbase.
No COLOR code listed.
F110 = F100 4WD, 5600 lbs. GVWR
D81: D = Light Beige Crush Vinyl & Medium Beige Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
N = New Process 435 4 Speed Manual Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
GVW omitted: It's 5,600 lbs. Gross Vehicle Weight Rating.
HP & RPM omitted.
DSO code omitted.
390 engine introduced in F100/350's in 1968, used thru 1976 in 2WD's only.
Since all 352/360/390/410/428 engines were originally cast as 352's, thru circa 1971, all have the foundry marking of 352 cast on the engine block.
The only power equipment available in 1965: Power Drum brakes.
Since all FE engines look identical, and...on sale day 352 engines magically become 390's, measuring the stroke is the easiest way to determine engine size:
Stroke: 352 = 3.50" / 390 = 3.78"
Old Sep 15, 2010 | 10:06 AM
46490's Avatar
46490
Thanks
Thank you for the information. Maybe the "G " that I wrote down was a "B" and my old eyes didn't catch it.
I was told that the motor was a 390 and my mechanic has been putting 390 parts on it.
Any numbers that I should look for on the axels and transfer case/trans so I know what I have for furture servicing and or parts?
Is there a book (mechanics) out there and is one better than another?
Again thanks for all the info.
Old Sep 15, 2010 | 10:15 AM
NumberDummy
Almost all the parts that fit a 390, also fit the 352 ... that was the only V8 offered in 1965/67 F100/350's.
The parts difference between a 352 vs a 390: The crankshaft, pistons and rods.
Old Jun 18, 2016 | 09:33 PM
ttempli1's Avatar
ttempli1
idk if you can do my vin or not. but i would greatly appreciate if you could. its F10YR777070
its a 1965 f100
Old Jun 18, 2016 | 09:46 PM
NumberDummy
It's a 1965 F100
Welcome to FTE
It's not a 1965 with a Y as the VIN engine code. D was used in 1965 for the 352, Y was used in 1966 for the 352.
The last 6 digits of the VIN is the serial number (aka Numerical Sequence of Assembly), decodes to the month/year truck was assembled.
F10 = F100 2WD
Y = 352 2V
777070 = 1966, assembled October 1965.
New vehicles are historically introduced in September of the previous year, so new vehicle production begins in August.
ashlockbrian
58
Mar 31, 2024 09:04 PM
Amphihauler
Nov 14, 2017 06:42 AM
pmason0
May 2, 2017 10:44 AM
awhtx
Large Truck
Apr 14, 2017 06:21 PM
bossmaverick
15
Jul 7, 2016 07:20 PM
