Wiring is eroding at sensors
after all the work i have done to my 04' f250 6.0 i found a tiny leak today that has been driving me nuts trying to find it. all fixed now. when i was trying to locate the leak i noticed several of the wires right at different sensor plugs have a bare wire like the insulation had eroded off the wiring. is this common? I'm gonna take a day and dab some liquid tape on the bare wires just so they don't corrode away. do they sell a replacement harness for the injector and sensors? also found a few sensor plugs broke were they won't seal. like have the out portion of the plug has cracked and broke.
True I preferr soldering to anytype crimp connector,but I been doing soldering connections for so long I sometimes forget to mention it. Guess I take for granted that everybody solders in. LOL
There is some good reasoning behind not soldering wires.
It has to do with the lack of flexibility and work hardening
of the wires. Where with crimping you still have individual
strands that can still flex to the crimp point.
But we could do a whole class on the subject and not even
start to cover things just in the automotive world let along
all the other uses. AND There are times where soldering will
be the better method.
DieselTechRon has a guy that he works with that has been able
to get a lot of the oddball connectors and at a good price from
what he has been saying.
You might want to send him a question and get the link to the guy.
DieselTechRon - Serving the Ford Diesel Community
Sean
Sean
I prefer to solder as well but these short wires need the flex in it like was mentioned so will do the crimp connect. nothing like replacing a connection and have a slight pull on the wire because the solder won't flex then ending up changing it again later cause the connection broke again. a couple that i found only have about 3/4" outside the harness loom and would be tight either way unless i pulled them completely out of the loom and did it but just doesn't seem feasible to tear the whole loom apart.
Rippin6Gears
01-17-2016 10:53 AM
GregonVI
09-17-2013 10:26 AM
ewford
12-28-2012 04:20 PM
