P1728/P1783 torque converter
Recently purchased a 1999 F250 4x4 7.3L. 213,xxx miles. The O/D off button has been flashing. I pulled the codes. P1728 (Transmission Slip Error-Converter Clutch Fault) and P1783 (Transmission Over Temperature Condition) From what I have researched my torque converter needs replaced. Apparently the apply piston is know for cracking and allowing pressure to bleed off causing higher revs and fluid temp increase? I did data log the truck and it showed that the tcc was being commanded to lock. It does seem that my revs are higher than what they should be while driving. Transmission shifts normally and smoothly, even while pulling a 7,000lb load. My questions are, Could this be anything other than a torque converter needing replaced? Since the trans shifts good, should I just put in a new converter and go? Will probably do pan drop and replace filter also. And a big question I have is what torque converter to go with??? I'm new to the truck/diesel world, always worked on mustangs. Truck will be daily driver, will have minimum mods and will tow maybe 8,000lbs occasionally. Would like a good quality converter that will transfer torque aquatically and is not terribly expensive. thanks for all help and input!
50th ann
03-24-2009 08:23 PM
flatbed350Stroke
08-04-2008 12:01 PM
termyt00
05-24-2007 11:49 PM
gov2mod
01-10-2005 03:15 PM
