5.4 shutting off while driving. Then starts back up?
I have a 2002 f250 5.4 and while I am driving it just cuts off. I then pull over wait for 10 seconds to 2 min and it starts back up. Then later down the road it will do it again. I have changed the fuel filter and that has helped in for a week or so then it does it again. I also changed the fuel pump and the same thing happened.
dies while driving and no start for some period of time
Had this problem with my E350 1997. I start and stop my vehicle a lot so put a lot of wear on the ignition switch. Mine was doing this same thing and I found the ignition switch was so worn that the contacts had become sloppy. Replaced the ignition switch (the plastic contactor at the base of your steering column that your key actuates when you turn the key) and the problem went away.
The following users liked this post:
JDPoore
12-26-2004 07:14 PM
Sryaxxalot
15
12-04-2002 12:02 AM
