my 300 build. please help
O k here goes. Iam planning to rebuild my 86 f150 engine. I have always had the desire to rebuild with it disguised as stock. And since i am missing all my smog gear, this is what i have come up with. 264 degree camshaft, dui distributor(to make up for the missing smog gear), 30 degree back cut on the valves, chevy roller rockers, a heavy duty exhaust manifold. I want to go to a bigger carb but not sure which one yet. Would be open to a bigger one barrel or the webber 32/36 2 barrel.
What do y'all think?
Any suggestions?
Any suggestions?
Last edited by phroldschool; 11-28-2014 at 07:56 PM. Reason: wanting help and suggestiona
Sounds like you have a nice list going so far.
There's definitely a large list of carbs to choose from. If it were me though, I would go with something bigger than a 1 barrel to take advantage of the other components you're throwing on it.
The common option is an Offenhauser 4bbl intake with a larger 2bbl or 4bbl carb. There's a large list of which ones work well, just do a few searches on the site.
The Offenhauser manifold should work just fine with it. It's designed to be used with the stock intake.
Offenhauser and Clifford are the only two I know of that are still in production, and both of them are for a 4bbl setup (or a 2bbl with an adapter). There are a slew of others that have been made over the years, and they're randomly on ebay.
Originally Posted by Larry at Clifford
Our intakes have an open plenum and nothing bolts to any of them without adaptors.
bmyers4
03-15-2013 08:51 PM
Burburan
06-14-2011 07:28 PM
DerekWolf
02-25-2011 04:15 PM
77'Sam
12-12-2006 08:15 PM
