beware doing the fuel filter change
I was hoping to use Baldwin. I use Baldwins on all my heavy equipment, boat, etc... I think they're a great filter.
After reading this thread I'm not so sure that's a good idea for warranty purposes.
Anyone have any experience with warranty and using an as good or superior filter than Motorcraft?
Received 3,568 Likes
on
If you are using something other than Ford and an issue arises, you better bet they are going to use it against you. Sure the blah blah law states that the part must be pinpointed to the failure, but they will not care, and you will have to pay massive attorney fees, experts etc to clear yourself. All because you wanted to use a Baldwin. Get my drift?
No problem.
Tim, I think no matter what, make sure you take her out for a decent drive every now and then and you should be fine with normal intervals. Letting any vehicle sit without use is not a good thing. Take her out, cycle through 4x4 etc, and keep everything lubed. I would change my oil once a year even if I never hit the change light.
Next time you change filters it will be super quick using your "complete spare" and then clean out the used one later.
I carry the spare housing and filter set with needed tools in the truck since we travel a lot. The filter and spare housing are in a separate tool box with some 1 gallon freezer zip-locs, plastic coffee cans and latex gloves.
Keep in mind, Ford or Motorcraft do not make filters.
I use the Motorcraft because DieselFIltersOnline sells them cheaper then any other brand. I usually order every two years with enough quantity of fuel oil and air filters along with Motorcraft fuel additive to get the free shipping.
Any name brand filter is good. I did almost 20 years as a Class A line tech for several Chrysler dealers. Oil filter brands were never an issue for warranty.
Ford cannot specify you use Motorcraft branded filters and oil. If they did they would have to supply it.
Now, why buy another brand if you can get the factory labeled stuff for the same or cheaper price?
How many here use only Mototrcraft oil?
And if your answer is you do use Motorcraft oil because you only get oil changes done at the dealer - are you sure you are still getting Motorcraft?
"Every" dealer I worked at had bulk oil tanks, and there sure weren't any "MOPAR" or "Motorcraft" tankers delivering oil.
Keep in mind, Ford or Motorcraft do not make filters. I use the Motorcraft because DieselFIltersOnline sells them cheaper then any other brand. I usually order every two years with enough quantity of fuel oil and air filters along with Motorcraft fuel additive to get the free shipping. Any name brand filter is good. I did almost 20 years as a Class A line tech for several Chrysler dealers. Oil filter brands were never an issue for warranty. Ford cannot specify you use Motorcraft branded filters and oil. If they did they would have to supply it. Now, why buy another brand if you can get the factory labeled stuff for the same or cheaper price? How many here use only Mototrcraft oil? And if your answer is you do use Motorcraft oil because you only get oil changes done at the dealer - are you sure you are still getting Motorcraft? "Every" dealer I worked at had bulk oil tanks, and there sure weren't any "MOPAR" or "Motorcraft" tankers delivering oil.
I understood what Sgt was saying but I asked because of the very reasons you stated above.
If I could get Ford to put in writing that it was okay for me to use Brad Penn oil and Baldwin Filters, that's what I would be running.
I think oils are a huge difference maker in these vehicles.
I'm very sorry to the OP for the thread jack. Oils & Filters could be a long thread themselves.
Thanks for the info.
#28
