beware doing the fuel filter change
I just did the fuel filter change and took my 32mm socket to the plastic nut and it cracked right off pouring fuel out. Thankfully, my local dealer had another one stocked. I bought a spare too. The location/plastic style, i dont know what ford was thinking. Just giving everybody a heads up! The piece costs me about $25... well worth buying 2.
Happens alot if you're not real careful. I use a strap wrench to turn that bowl after learning of others misfortune on here.
I used a strap and the socket till it broke the seal. Be sure to put some fresh oil on the o-ring.
I think a dry o-ring is part of the problem. |
Originally Posted by senix
(Post 14761964)
Originally Posted by Troy Buenger
(Post 14762172)
The last Motorcraft fuel filter I purchased had the O-ring pre lubricated.
I've changed my filters every other oil change or about every 15,000 miles and I now have 137,000 miles on my truck. I just changed my fuel filter again. I've not broken or had a problem with my cap. I do oil the O-ring, I do use a strap wrench and my 32 mm socket. Applying pressure to both wrenchs at the same time.
Originally Posted by Painted Horse
(Post 14762539)
So when you guys are changing filters do you stick with Ford filters? I'm thinking for Warranty I should buy filters from Ford. Or are there others that will still be OK like WIX.
Thanks to the antwan181 I will be very cautious when removing the fuel bowl. I might even buy an extra because it is a 125 mile round road trip to the dealer. |
Tim, I would stick with Ford. I'm at the point where I let them do the maintenance, that way they can blame themselves :)
I think so to Steve, I just thought I would ask and see what the general consensuses was.
I wouldn't chance it Tim, it's just not worth it.
Originally Posted by Tim Young
(Post 14762775)
I'm not worried about cheaper, I'm worried about the warranty.
Wix is great for sure, I'm with Tim though about the warranty. I don't want to give them a reason.
I stick to motorcraft as well.
Even pressure with the strap wrench and the socket is the key. Have to go slow, a few pops/squeaks at a time. |
