My 03 Nightmare
My 03 Nightmare
So I have a feeling this truck really hates me...
Heres the story, early build 03 with roughly 66k on the clock. Came into the shop with a no start and the fuel pump making a horrendous noise, so I check the upper fuel bowl and it fills extremely slow...simple needs a pump.
I install the new FORD pump, fresh filters, bleed the system, fires right up. Took it for a test drive, truck runs like a scolded cat, I figure nice. I call the customer tell him to come and get it, I go to pull the truck up front and she no start. The truck cranks over strong, has good ICP, IPR looks good at 45%, glow plugs are working, and the fuel bowl is filling fast. So I check it for codes now I have a P2614 CMP CKT Open/Shorted...AWESOME.
Looks like the truck has had a rodent in there at some point, I found a few chewed wires at the passenger side fender. Guess I need to dig deeper and see what else is going on with this truck.
Sarge
Sarge
Rusty knows the type of splice kit I would be using if it were me.
Now on the chewing part I hear that red pepper extract works really well
in getting then to go over to the Chevy shop and chew there.
EDIT : Found it >>> Stop The Rodent
Then there is this stuff
Hot pepper spray repels pests off fruit trees so you can enjoy your harvest.
Fruit trees are irresistible to many mammals and pests that enjoy the bark, leaves and fruits. Some pests can remove all small tender fruits overnight and leave you without a harvest. Other pests can chew enough bark off young trees to allow diseases and pests into the trunks that can kill a tree. You can make a homemade liquid hot pepper spray for a very nominal price to rid yourself of these unwanted pests. Hot pepper sprays are a humane way to treat these types of pests, as it is a repellent and does not kill or harm animals.
How it Works
Peppers contain the naturally occurring substance capsaicin. Mild peppers such as banana and bell peppers have smaller amounts of capsaicin, while chili, cayenne, habanero and Tabasco peppers contain larger amounts of capsaicin and are much hotter. It is these hot peppers that are used to make a spray to protect your fruit trees from pests. When insects and other animals come into contact with the solution, they will be deterred by it and will not eat anything near it with that distinctive smell or taste.
What it Repels
Homemade hot pepper spray repels chewing and eating animals such as raccoons, deer, rabbits, voles and birds. It is also a deterrent to dogs and cats. Some dogs enjoy chewing the lower leaves of young, tender fruit trees. Deer and birds usually eat the small fruits off a tree. Raccoons, rabbits and birds chew fruit tree trunks and cause damage to them. Pepper spray repels small pests -- including spider mites, aphids, lace bugs and leafhoppers -- that thrive on fruit tree leaves and damage them by sucking out the fluids. These insects usually appear on the underside of fruit tree leaves and are very small -- you may need a magnifying glass to find and identify them. It is important to note that hot pepper spray will not kill infestations, but will repel future insects. Use of an insecticide first to kill the insects followed by applications of hot pepper spray is a way to treat fruit trees that are already infested.
No Matches Found. Please try your search again.
Ingredients
There are many recipes for homemade hot pepper spray. Common ingredients are cut peppers, powdered cayenne pepper or Tabasco sauce, which contain capsaicin. Other ingredients may include garlic cloves, onions or chili powder, which add a strong scent to the recipe. To make a hot pepper spray, chop one large onion and one jalapeno pepper. Add this to 2 quarts of water and sprinkle 1 tablespoon of cayenne pepper into the mixture. Boil the ingredients on the stove top for 20 minutes. Allow the mixture to cool and strain it through cheesecloth into a garden sprayer. You can also choose to use dried ingredients instead of fresh ones. Recipes that contain all powdered ingredients do not need straining. Be sure to wear rubber gloves when handling hot peppers. Capsaicin can cause severe irritation to your skin and eyes.
Application
Make the spray in the spring when leaves first emerge to ward off pests before they strike. Apply hot pepper spray every two to three days to your fruit trees. It is best to spray all areas of the tree including the trunk, branches, fruits and leaves. Make certain to spray the undersides of the leaves thoroughly where insects often reside. Spray the ground around each fruit tree in a 3-foot circle to discourage pests from getting near your fruit trees. Reapply the spray after it rains or after a very heavy dew or fog. Use caution when applying the spray and ensure that the wind doesn't blow it into your face or onto your skin.
References (7)
Resources (3)
About the Author
Mary Lougee is a writer in Texas who writes on a wide variety of subjects from home improvement to pet care. Her love of animals led to building a farm and caring for rescue animals from equine and swine to dogs and cats. She holds a bachelor's degree in management.
Credit goes to >> Homemade Liquid Hot Pepper Spray for Fruit Trees | Home Guides | SF Gate
Sean
How it Works
What it Repels
Ingredients
Application
References (7)
Resources (3)
About the Author
Sean
Hope that helps,
Sarge
