PS pump & AC clutch
#61
#63
#64
I've replaced the water pump, the vacuum pump (a few times) and the alternator. The only things left to change is the tensioner (I have a belt routing sticker and a spare bracket to do the dual mod) and the AC.
Does changing the front seal on the compressor mean depressurizing? I'll forgo that as that seal ought to be lubricated with the freon's oil.
You bought all motor craft parts, would you have bought someone else's if you had the time?
#65
#66
Well, it didn't work! The ac clutch kit that I installed, according to a friend, is to much for the compressor to handle and blows out the seal on the compressor shaft. Mine is blown and spraying Freon all over. So much for that attempt to save some money but I still feel that it was worth a try!
Just brought up a old thread for information purposes!
#67
#69
#70
I replaced the whole AC system myself. Wasn't hard. The auto skills shop on post helped vacuum the compressor for a couple bucks. i didn't realize that the Ford AC on these trucks blew so cold! And when I took the old compressor apart, the clutch had completely blown up, bearings seized and it was a mess.
Glad you got home Glenn!
#71
Richard
#72
#74
Just be sure that the system is flushed with the right chemical or you will loose your new compressor in short order.
Richard
