anyone use this ford racing oil filter
Here's what Ford says about it.
I don't see how it's worth 4X the price of a regular FL-820S. If I wanted an upgrade from the FL-820S, I'd get a Fram Ultra for $8 at Walmart.
Sent from my HTC ONE using IB AutoGroup
FORD RACING HIGH PERFORMANCE OIL FILTERS
Synthetic-Polymer/Cellulose-Fiber blend media.
Heavy gage base and canister for higher burst strength and impulse fatigue resistance
High quality silicone anti-drain back valve
Non-stick sealing gasket for ease of installation and removal
Long life with standard and synthetic motor oils
Up to 50% more filtering capacity then standard filters
Improved filtering efficiency
This technology is only available through Ford Racing Performance Parts.
Can be used in many FL500 applications
These "racing" filters are exactly the same size as the FL-820S, and have a higher flow rate. They also have higher efficiency, so they flow better and take more contaminants out of the oil than the regular Motorcraft filters. Still not worth 4X the price IMO. The FL-820S is an excellent filter and only costs around $4.
Originally Posted by jesse5
"Can be used in many FL500 applications "
Sounds like construction of Mobil1 filter.
This is smaller diameter than FL-820S.
What is the application?
I only use the FL-820S as you need to keep the flow
up just as Ford designed it for the OHC's."
"The regular Motorcraft filters are made by Purolator. I'd imagine these are as well. Mobil doesn't make oil filters. "Mobil 1" branded oil filters are made by Champion Labs, which is actually part of Fram.
These "racing" filters are exactly the same size as the FL-820S, and have a higher flow rate. They also have higher efficiency, so they flow better and take more contaminants out of the oil than the regular Motorcraft filters. Still not worth 4X the price IMO. The FL-820S is an excellent filter and only costs around $4."
"The regular Motorcraft filters are made by Purolator." true
"I'd imagine these are as well."
"Mobil doesn't make oil filters. "Mobil 1" branded oil filters are made by Champion Labs, which is actually part of Fram." true
"These "racing" filters are exactly the same size as the FL-820S" false
"They also have higher efficiency, so they flow better and take more contaminants out of the oil than the regular Motorcraft filters" can't have both
The factory uses the very low filtering efficiency FL-820S so the engine has the highest flow of oil.
there does seem to be some reported differences in efficenciy of particle trapment as well as overall amount of grams of collection before going into bypass.
there are also psi differences for by pass mode
it would be great to know when a filter is full and in bypass mode....especially if you run long drain intervals.
I also wonder if there is a difference in reverse flow valve functionality if you use dino, blend, syn.
But, Im not believing that the racing filter is just a painted white version of the FL-820. It shouldnt cost an extra 12 bucks to paint it white.
I don't know about this particular filter, but I do know that most of the time you are just paying for a name and not the actual product. I drive a tanker and I haul all sorts of chemicals from oil, antifreeze, fabric softener, laundry detergent, etc, and I am in the manufacturing/packaging plants daily. I will watch them run a batch of something name brand that is $10 and then immediately run a store brand into a different bottle and it costs $5. I watched 5 different brands of antifreeze get bottled out of the same tank I just unloaded, nothing different about them at all, no additives, etc.
so I received one today. a very heavy filter. easily double the weight of any of the top sellers (wix, mobil 1, bosh, stock motorcraft, AC, champ, fram, purolaator, etc) so its not a painted white version of a shelf item.
no spec's anywhere to be found terms of percent efficiency at a given micro, psi for by pass, number of grams it traps. heck, I'd like to know if the anti-reverse flow works any better.
one interesting thing the box says...drain interval of 3000 miles.
