Which oil filter- 3.5 EB?
Old Oct 2, 2016 | 06:39 PM
SIXD9R's Avatar
SIXD9R
Post Which oil filter- 3.5 EB?
Hello, I did my first oil change at 3500 miles and the oil sure did look dirty. I know that's not necessarily a proper analysis but just thought I would mention it.
What I wanted to ask (without starting brand war) is what oil filter are you running? I have been using Fram Tough Guard filters in my vehicles for some time now and have not had any issues. I couldn't help but notice the Fram filter for this application is a little shorter than the OEM filter. Or is the original filter longer than Ford/motorcraft replacements? See pics below. I also checked Wix brand filters online and the case dimensions are identical to the the Fram. It's probably okay especially since I change my oil at sooner than recommended intervals but a smaller filter is concerning to me.
Thanks for your time!
Rick
Last edited by SIXD9R; Oct 2, 2016 at 06:42 PM. Reason: Sorry- forgot to add the pics
Old Oct 2, 2016 | 06:47 PM
onug's Avatar
onug
I always use the OEM filter, Motorcraft FL-500-S.
Old Oct 2, 2016 | 07:01 PM
brokenleg's Avatar
brokenleg
motorcraft
Old Oct 2, 2016 | 08:47 PM
j.grif's Avatar
j.grif
I use the motorcraft fl500s also, and yes the original filter is a little larger.
Old Oct 2, 2016 | 10:28 PM
Tom's Avatar
Tom
I also use Motorcraft. No need to reinvent the wheel here, and I generally think those who designed my engine are best qualified to design the oil filter. Nothing against Fram, but you can't go wrong with OEM parts.
Old Oct 3, 2016 | 05:07 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
MC filter for Ford applications. I also always used Fram filters till I became a member here and started seeing small differences in filter construction. My older Ford always got a 3000 mile oil change and a filter should last fine for 3K miles. However, on the new trucks, Ford has said to follow the OLM for oil change recommendations which can run up to 10K miles. I dump every 5K-6K miles.
Old Oct 3, 2016 | 11:50 PM
QwkTrip's Avatar
QwkTrip
Comparison of oil filter construction.
http://hillerford.com/resource_libra...aftcompare.pdf
Old Oct 4, 2016 | 07:21 AM
Jus Cruisin's Avatar
Jus Cruisin
Motorcraft.
Old Oct 16, 2016 | 07:36 PM
SIXD9R's Avatar
SIXD9R
Thumbs up
Hi guys- I apologize for the delay in getting back to a thread that I started. But a big thank you to everyone that replied especially J.Griff for the picture and info showing the original filter being a little larger. Also special thanks to QwkTrip for the link to the oil filter comparison.
In the filter comparison, I noticed the Wix brand that I sometime use seem pretty good. Actually more filter media than the Motorcraft.
Thanks again and happy truckin!
Old Dec 8, 2016 | 08:05 AM
Wacky Wick's Avatar
Wacky Wick
SIXD9R, with your Wix filter do you have any noise at start up? Was this fiter the Wix XP ?
Old Dec 9, 2016 | 11:08 AM
David W Jones's Avatar
David W Jones
Look at the Baldwin B7449.
Old Dec 11, 2016 | 04:58 PM
advocate's Avatar
advocate
The Fram Tough Guard and Ultra line have proven to be great filters. Silicone adbv and synthetic filter media. Better quality construction then the motorcraft and Wix, better filter media. And better filtration ratings. Up to 99.9% at 20 microns vs only 80% at 20 microns for the motorcraft. It also has more capacity. The purolator made motorcrafts have been failing the past few years. Nothing has been done to correct the issue. Torn filter media issues.
Fram may get a lot of hate on on the internet. But they are one of if not the biggest filter company. They stand behind their product. And their quality has improved significantly. I used to hate them. Now I won't use anything but them. Why hold a grudge? They have turned around and make great filters!
King Rex
6.2L V8
13
Feb 4, 2014 04:59 PM
Jack-o
Jun 13, 2011 08:57 PM
landis76
May 3, 2010 10:38 PM
rsylvstr
Modular V8 (4.6L, 5.4L)
Jan 12, 2007 09:47 AM
Hotwheelbill
Jan 24, 2006 10:56 PM
