Oil & Lubrication
oil filter questions
Old Apr 27, 2002 | 11:24 AM
Stab's Avatar
Stab
I use purolator oil filters on everything except Fords and I use Motorcraft for them. I think Motorcraft is made by Purolator anyway. Does anyone have any bad expierences with Purolator? I have had very good results and was wondering if there is something I don't know about. I have also heard Wix and Hastings were good. Are they better?
The federated house brand oil filter I saw recently said "Hastings" on the side of it. I also understand Wix makes the Napa brand. I'm just wonering if there is a filter out there "better" than the Purolator.
BTW, I use the standard filter and not the pureone. I have some worries that the filters with the very small micron filtration capabilities will bypass more oil than a standard filter. No reason for that just a personal thought. Is that the case? It seems that those filters would take longer to filter the oil and bypass a lot of unfiltered oil in the process.
Later
Stab
Old Apr 27, 2002 | 07:43 PM
pcmenten's Avatar
pcmenten
[updated:LAST EDITED ON 27-Apr-02 AT 08:43 PM (EST)]Hi Stab,
I read the oil filter study done a few years ago, the one that slams Fram oil filters so badly. One of the criteria that was measured was the total surface area of filter media in the filter. So here's my point; if the filter media is of a smaller micron size and therefor more restrictive to oil flow, that can be compensated for by increasing the total filtering area.
Amoung the other shortcomings of the Fram filter was a relatively smaller filter area. The Purolator, Wix and other quality filters had a good size filtering area.
A copy of the web page that compares oil filters can be found at [link:www.dorianyeager.com/oilfilterstudy1.html|this web site]. I've read through it a few times. I love this sort of DIY research.
Best regards,
Old Apr 28, 2002 | 09:28 PM
GreenMachine's Avatar
GreenMachine
Here's another filter study done by other FORD lovers.
http://www.shoclub.com/lubrication-oil/lubrication-oilpart1.htm
Old Apr 29, 2002 | 10:57 PM
bubba4fl's Avatar
bubba4fl
Hey Stab,
I've been using Purolator for at least ten years ( I can't remember past that). I've had no problem. My 300 6 cylinder has 180,000+ miles on it and is still going strong. Unless you're into racing, I believe most filters are pretty much the same. Now you know - BUBBA
Old May 1, 2002 | 09:49 AM
CrashCrowe's Avatar
CrashCrowe
