Radio installation
Radio installation
So, I finally got around to trying to install the stereo I purchased back in February. I bought the RetroSound radio that "fits in your dash" from LMC. Sure enough, it fit in the hole in the dash. Problem was I didn't see any way to mount it. So I went back to LMC and ordered the "Universal Dash Mounting Kit", which included the control ***** that for some reason did not come with the radio.
The "Universal Dash Mounting Kit" did solve the problem of the radio falling out of the hole, but something just isn't right.
Now I do understand that the plate is supposed to be trimmed to fit. But I don't think any amount of trimming is going to make a flat plate mount against a curved surface.
So what do I do? Do I take a torch and melt the plate to the surface to fit? Do I hammer the dash flat? Do I buy a Chevy? (Yes, I am kidding)
What would you do?
What would you do?
First thing I would do is call LMC and see if they have used that universal mounting plate in your year of truck and if so what did they do.
More than likely tho you are going to adapt.
I would make a box- 6" deep, height = opening of dash hole and should be the height of radio plus some, width = opening thru dash
With the face vertical to the lower face of dash slide it in the opening and scribe the radius of the dash onto the box sides.
Cut and weld a flange onto the sides
Leave flange material on the horizontals
Using the universal mount as a template copy openings onto the bottom of box which became the face and cut them out
If you have interference or other issues the radio face does not have to be vertical it can be at an angle but box demensions will change
My sheet metal instructor once told me if ya can't see don't cut it so make sure you can visualize it
Measure twice cut once
Use cardboard first always helps
I bought a factory adaptor plate off of Ebay (took eight years to find one) that adapts a 1951/52 radio into a 1948/49/50 dash, then made another plate for behind that one to fill the gap between the factory plate and the Retro sound radio. The factory plate is curved to match the dash. regards
You may want to look at this site. It is the Retro sound web site. https://www.flickr.com/photos/cntstp...7644258454104/
It shows faceplate options.
I'm assuming the plate is a piece of plastic. You can usually get it to soften with a good quality heat gun. Place the empty piece of plastic over something round, close to the contour of the dash, and start going from side to side until it get pliable and they form it to fit. At least that's what I'd try doing.
