Radio installation
Old Oct 2, 2014 | 06:37 PM
JPMallory's Avatar
JPMallory
Radio installation
So, I finally got around to trying to install the stereo I purchased back in February. I bought the RetroSound radio that "fits in your dash" from LMC. Sure enough, it fit in the hole in the dash. Problem was I didn't see any way to mount it. So I went back to LMC and ordered the "Universal Dash Mounting Kit", which included the control ***** that for some reason did not come with the radio.
The "Universal Dash Mounting Kit" did solve the problem of the radio falling out of the hole, but something just isn't right.
Now I do understand that the plate is supposed to be trimmed to fit. But I don't think any amount of trimming is going to make a flat plate mount against a curved surface.
So what do I do? Do I take a torch and melt the plate to the surface to fit? Do I hammer the dash flat? Do I buy a Chevy? (Yes, I am kidding)
What would you do?
Old Oct 2, 2014 | 07:39 PM
schoo's Avatar
schoo
I have used a parts truck took the dash and cut a piece out to fill a hole that was cut out of my 64 the po had a radio that was not stock
I would think that with a little fab work you could make your own trim
Old Oct 2, 2014 | 07:42 PM
gerrymoe's Avatar
gerrymoe
First thing I would do is call LMC and see if they have used that universal mounting plate in your year of truck and if so what did they do.
More than likely tho you are going to adapt.
I would make a box- 6" deep, height = opening of dash hole and should be the height of radio plus some, width = opening thru dash
With the face vertical to the lower face of dash slide it in the opening and scribe the radius of the dash onto the box sides.
Cut and weld a flange onto the sides
Leave flange material on the horizontals
Using the universal mount as a template copy openings onto the bottom of box which became the face and cut them out
If you have interference or other issues the radio face does not have to be vertical it can be at an angle but box demensions will change
My sheet metal instructor once told me if ya can't see don't cut it so make sure you can visualize it
Measure twice cut once
Use cardboard first always helps
Old Oct 5, 2014 | 04:24 PM
carbs & chrome's Avatar
carbs & chrome
That's a universal mount for a flat dash / panel. Looking at the catalog LMC does not offer a mount for the 48-52 dash. You'll probably need to fab something up yourself. What's the existing hole look like?
Old Oct 5, 2014 | 04:39 PM
JPMallory's Avatar
JPMallory
I'm thinking about buying the radio hole cover for the 48-50, since I know it's contoured for the dash, and then cutting out the holes I'd need to use it as my faceplate.
Old Oct 5, 2014 | 06:15 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Since they're plastic you will still need to come up with a solid mounting bracket for the radio.
Old Oct 6, 2014 | 09:12 AM
rustybits's Avatar
rustybits
I bought a factory adaptor plate off of Ebay (took eight years to find one) that adapts a 1951/52 radio into a 1948/49/50 dash, then made another plate for behind that one to fill the gap between the factory plate and the Retro sound radio. The factory plate is curved to match the dash. regards
Old Oct 6, 2014 | 09:21 AM
ChuckRob's Avatar
ChuckRob
I had a hard time trying to figure out how to make the radio look good. It's kind of like putting a square peg in a round hole. I changed directions and mounted it in the speaker hole, I think it looks good and it works well, not exactly stock but who cares.
Old Oct 6, 2014 | 09:48 AM
JPMallory's Avatar
JPMallory
I like it. I would probably steal that idea if I didnt already have a speaker installed in that spot.
Old Oct 6, 2014 | 10:01 AM
yamagrant's Avatar
yamagrant
Can you heat the plastic with a heat gun and form it to the dash? Good luck.
Old Nov 30, 2014 | 12:24 PM
3golfjack's Avatar
3golfjack
You may want to look at this site. It is the Retro sound web site. https://www.flickr.com/photos/cntstp...7644258454104/
It shows faceplate options.
Old Nov 30, 2014 | 05:40 PM
tip49's Avatar
tip49
Original bezel
The original bezel fits from behind the dash into the radio opening. Can you fab up a bezel that will fit through the hole and have a flat face to it ?
Tom
Old Nov 30, 2014 | 05:59 PM
bobj49f2's Avatar
bobj49f2
I'm assuming the plate is a piece of plastic. You can usually get it to soften with a good quality heat gun. Place the empty piece of plastic over something round, close to the contour of the dash, and start going from side to side until it get pliable and they form it to fit. At least that's what I'd try doing.
Old Dec 1, 2014 | 04:58 AM
JPMallory's Avatar
JPMallory
I may try that. Worst I could do is ruin it, and it's not like it's much good the way it is now.
Old Dec 1, 2014 | 12:20 PM
AXracer's Avatar
AXracer
Can you weld? If so it would not be difficult to fab a metal plate that would mount the radio.
