02 front parking lights issue
#31
Does anyone know the routing and where it starts/stops in relation to the front parking lights? Trying to find out where I'm loosing power in the brown wire to the front. Does it go fuse box to switch to gem to the front passenger or driver side to the lights? I want to check power at each point and any plug junctions in the harness. Can't seen to find the info I'm looking for.still open to suggestions on what it could be.
#32
I already told you that the GEM is not involved so take that off your mind.
The front/rear split is in the Central Junction Box.
The front park lamp circuit comes out of the CJB on connector C270h, Pin 3 (The rear comes out C270j, pin 12). It then goes to a single splice S107 located somewhere at the "Engine compartment, rear". From that splice, it goes to the individual lights. There is no further location information in the factory manual.
Your open circuit is likely in the CJB, at C270h-3, or between the CJB and splice S107.
So the rear works like I said, so where would I start in the front/where does this brown wire run to/from?
#33
#34
hockeypundit
23
10-08-2012 09:07 PM
Wicked Endings
11-28-2010 10:34 PM
oz9609
03-19-2001 09:39 AM
