1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
02 front parking lights issue
  #31
Old 10-01-2014, 10:27 PM
rollin_coal's Avatar
rollin_coal
rollin_coal is offline
Does anyone know the routing and where it starts/stops in relation to the front parking lights? Trying to find out where I'm loosing power in the brown wire to the front. Does it go fuse box to switch to gem to the front passenger or driver side to the lights? I want to check power at each point and any plug junctions in the harness. Can't seen to find the info I'm looking for.still open to suggestions on what it could be.
  #32
Old 10-02-2014, 06:43 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
I already told you that the GEM is not involved so take that off your mind.
So the rear works like I said, so where would I start in the front/where does this brown wire run to/from?
The front/rear split is in the Central Junction Box.
The front park lamp circuit comes out of the CJB on connector C270h, Pin 3 (The rear comes out C270j, pin 12). It then goes to a single splice S107 located somewhere at the "Engine compartment, rear". From that splice, it goes to the individual lights. There is no further location information in the factory manual.
Your open circuit is likely in the CJB, at C270h-3, or between the CJB and splice S107.
  #33
Old 10-02-2014, 09:09 AM
rollin_coal
I don't have a good manual.I'm just going off info I've read on here, it looked like the gem and some security box were in the link also, maybe not. Is the cjb the fuse panel under the driver dash? Is there also a parking lamp relay somewhere?
  #34
Old 10-02-2014, 07:16 PM
rollin_coal
Well, as frustrating as that was, the front parking lights now work.What fixed it, I don't know.I was looking for the brown wire behind the driver side fuse box and suddenly they now work.Thanks to all that had input.
  #35
Old 10-03-2014, 06:44 AM
projectSHO89
That would suggest a loose or corroded connection back there.
At least you have a general area to focus on should it come back.
Good luck!
hockeypundit
23
10-08-2012 09:07 PM
Wicked Endings
11-28-2010 10:34 PM
jaym69
2004 - 2008 F150
09-10-2006 05:45 PM
torinoman
Electrical Systems/Wiring
05-09-2006 10:37 PM
oz9609
03-19-2001 09:39 AM
Quick Reply: 02 front parking lights issue
