Sponsored by: Real Truck
Vin info
Old Jun 29, 2014 | 02:34 PM
53Tow's Avatar
53Tow
Vin info
I just got a 1994 ford f350 for my 1953 ford f350 the ser. 1FTJW36H5REA32380 I need to know the engine, trans, front and rear ends ,gears.
Thank you
Kevin
Old Jun 29, 2014 | 02:47 PM
redford's Avatar
redford
FTE Leadership Emeritus
Type
8 Cylinder Engine
Displacement L/CI
5.8/351
Fuel Type
Gasoline Fuel
4dr 168" WB SRW 4WD
2-speed transfer case
4.10 rear axle ratio
72 amp-hour (650 cca) maintenance-free battery
95 amp alternator
8' box
168" WB
9200# GVWR/3575# maximum payload
5000# capacity mono-beam front axle
6250# capacity rear axle
HD gas shock absorbers
4100# capacity front/7596# capacity rear springs-inc: auxiliary rear springs
(4) 7.0K 8-hole wheels
Pwr steering
37.2 gallon fuel tank-inc: auxiliary fuel tank
Old Jun 29, 2014 | 02:54 PM
Bigpipes 35's Avatar
Bigpipes 35
Wow nice work Stuart, Reps sent..
Old Jun 29, 2014 | 03:16 PM
53Tow's Avatar
53Tow
Thank you very much. Any idea on trany specs
Old Jun 29, 2014 | 03:19 PM
Bigpipes 35
If its a auto it will be a E4OD...
Old Jun 29, 2014 | 04:14 PM
53Tow's Avatar
53Tow
5 speed 4 wheel drive
Old Jul 3, 2014 | 05:36 PM
redford's Avatar
redford
ZF-5, specificaly the S5-47.......I think..
Old Sep 25, 2014 | 02:22 PM
53Tow's Avatar
53Tow
Does anybody know how to find out what 5.8 I have in this truck. I want to change the intake and put a carb on it.
Thank you
Kevin
Old Sep 25, 2014 | 03:39 PM
phillips91's Avatar
phillips91
Will you be using the truck for towing or just for fun? With your user name I am assuming towing. The reason I ask, is if you are using it just for daily driving then you would be better off getting a transmission out of a 150 because it is a true 5 speed with a more useable 1st gear and better gear spacing. The zf series is a 4 speed with 1st being what used to be called "low." Great for getting a load moving, but useless for daily driving.
Old Sep 29, 2014 | 10:11 AM
53Tow's Avatar
53Tow
I need the 5 speed with a PTO cover What I need to know is where the engine was made so I can change it over to a carb
Thank you
Old Oct 2, 2014 | 09:35 AM
53Tow's Avatar
53Tow
What engine
I think it is a Windsor but not sure. does anyone know how to find out
Old Oct 2, 2014 | 10:24 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is a Windsor. The others went out of production a long time before this truck was built.
Old Oct 3, 2014 | 09:10 AM
53Tow's Avatar
53Tow
Thank you
Kevin
Farmtruckn
Aug 2, 2015 12:30 PM
hosscat76
Aug 28, 2014 07:45 AM
StanleyZ
Feb 20, 2014 07:53 AM
Michael Hopton
May 23, 2012 09:06 PM
pelletman
22
Jan 15, 2007 09:16 PM
