Drivers Side Window Auto-Up
Does anyone have problems with the auto-up feature on your windows? Mine seems to randomly stop working from time to time. Only the drivers side has the problem. When the truck was new the dealer re-programmed the computer and put a new window switch in. That worked for a while but the problem keeps coming back. I can easily do the re-programming sequence however the problem always comes back. I have a 2012 Lariat SCREW.
You can always bring this up the next time you're at your dealership; I know they'd be happy to check it out. How many miles are on your trucks?
Crystal
This happens on occasion on my WK Grand Cherokee. The chrysler reprogramming method for these auto up windows is to open both windows all the way, manually close both (first detent, not auto up) and hold the switch at that first detent for 10-15 seconds after closure. It sometimes takes one or two attempts.
After that it works normally. Don't know what the Ford auto-up relearn procedure is but I am sure it is something similar. Might be worth a google.
The sequence is:
1. power the window down while pushing and holding the button all the way down.
2. power the window up while holding the switch all the way up till the window stops.
3. release the switch the pull all the way up & hold for 1 second.
Auto Up is now re-programmed. I do this in my sleep.
Work has a fleet of F150s, I do believe the oldest ones are 2011's and the newest ones 2014 and a few of the trucks have issues where the window will go down and not back up. Makes for a miserable ride come poor weather.
Mine has on a few occasions been a couple of taps to get the auto up to do its thing. Drivers window, passenger seems fine but I don't usually have passengers or use the passenger window.
Heard the dealer changes out the switch and tada it works, but we tried to swap switches on the road to just close the window and no dice. Mine wouldnt work in his and when i plugged his in to my truck nothing, but put mine back in my truck and all good. Thoughts?
RockyMtnRanger
03-06-2008 07:22 PM
