1996 7.3L Idler Pulley
Old 09-15-2014, 01:31 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
Hi Guys
Does anyone know the part number of the idler/tension pulley that's under the alternator on the passenger side front of the motor. Mine decided to eat its self and I need to replace the whole assembly.
Thanks in advance
Old 09-15-2014, 07:03 PM
breedo99's Avatar
breedo99
breedo99 is offline
You can get just the pulley itself, i had to do it on mine. Got it at napa. The only thing they asked was if it was smooth or had the ribs on it
Old 09-15-2014, 07:12 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Go with the super duty tensioner mod. It requires you to get a new belt also. The benefit is the sd has two idlers on the tensioner, so the tensioner arm will not have so much strain on it and pull off track as it gets older. Best i can explain it.
Old 09-15-2014, 11:37 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Gabe is right, I have a link at home if you want it.
Old 09-16-2014, 12:03 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
I'll take it Glenn!
Old 09-16-2014, 12:51 AM
coreyallan01's Avatar
coreyallan01
coreyallan01 is offline
OP, make sure you get yourself a long 1/2" breaker bar if you do the SD idler; son of a drumstick that thing has some spring tension!!!!
Old 09-16-2014, 02:10 AM
stainlessstroker95
f8uz6b209ca tensioner f8tz8620fb belt f8uz8b656ab new decal
Old 09-16-2014, 07:09 AM
gasman6674's Avatar
gasman6674
Thanks to all that responded. I am going to put stock unit back on it as truck is for sale currently. Thanks for the feed back
Old 09-16-2014, 09:00 AM
oldbird1965
Old 09-16-2014, 02:07 PM
BBslider001
Thanks Glenn!
amdriven2liv
06-18-2017 10:01 AM
el_gringo
1999 to 2016 Super Duty
06-03-2012 10:37 PM
MissIndependent
52
07-25-2009 07:56 PM
ChunderDownUnder
05-17-2009 09:29 AM
Tom92F150
04-08-2007 03:24 PM
Quick Reply: 1996 7.3L Idler Pulley
