Testing a MAF with OHM / Volt meter?
I tried spraying propane and starter fluid around and couldnt find anything. The code doesn't always come up right away, sometimes it may last 600 to 1200 miles without a code. It never runs rough, even when the code is on, the throttle response is just a little unresponsive
Thats why I was thinking maf.
checked the MAF using the scan tool.
At idle 3 g/s and increases as throttle is applied, this seems normal from everything I have read. I guess this eliminates the MAF.
another Idea I have is Maybe the brake booster is leaking air into the system, it is connected to the intake tube downstream of the maf sensor. I guess I could try to cork that off for a week and see what comes about.
just for kicks here is some of the data i recorded at idle
intake pressure 4.5psi
fuel trim idle -4 to 6%
fuel trim long term 12.5%
fuel pressure 38.17 psi
fuel flow .21 GaL / HR
Evap sys pressure -25.75 pa
