Code P0174
Old Nov 25, 2006 | 09:16 AM
AJ-69's Avatar
AJ-69
Code P0174
All,
I have a buddy that has a code of P0174 reading "system too lean" - bank 1 & 2
I have already changed the fuel filter on his vehicle and he is still getting this (what we beleive to be) fuel related code.
Any help is greatly appreciated.
Old Nov 25, 2006 | 07:16 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I'd say most likely a vacuum leak.. or a dirty Mass Air Flow sensor.
Check all vacuum hoses and connectors.. if all good spray some carb cleaner around the intake mating surface with it idling.. if you notice a change in idle, you've found your leak. Some intake leaks are very small and can be very difficult to find... sometimes you just have to replace it and hope for the best.
First though you might try removing the MAF and cleaning it... that can cause goofy things with the fuel mixture.
Good luck.
Old Nov 25, 2006 | 08:06 PM
steve(ill)'s Avatar
steve(ill)
http://www.obd-codes.com/forums/1106...amp-p0174.html
Old Nov 26, 2006 | 11:47 AM
AJ-69's Avatar
AJ-69
Thanks guys,
I will look into it.
Old Nov 26, 2006 | 04:06 PM
Coastiejoe's Avatar
Coastiejoe
What model Explorer is it. If it s the Sport or Sport Trac I have pictures of the issue...
Old Nov 27, 2006 | 02:19 PM
99xploder's Avatar
99xploder
I am getting the same error on my 99 explorer. It started after I had the fuel system cleaned and after I reset it the check engine light comes on when I run the floor/defrost on my heater. It runs like a champ but is a pain having to reset it each time.
msradio
Jan 22, 2013 08:16 AM
wildabeast
1997 - 2003 F150
May 27, 2010 09:31 AM
njxlt
Sep 16, 2006 10:15 AM
Ultramagdan
1997 - 2003 F150
13
Jun 27, 2005 10:10 PM
m68162
Nov 6, 2003 11:47 PM
