I have a coolant leak under the intake coming from the water pump.Its the metal line. My problem is it doesn't go to the firewall it makes a u shape comes back then it breaks off to 2 then the heater hoses connect. The car only has 52,000 miles on it doesn't look like anyone has ever worked on it. I cant find the hoes i need.I almost forgot i have a 1999 Navigator with the 5.4 32v DOHC Intec engine.
Hmm, it's been a while but I believe once you remove the bolt holding the metal tube the tube pulls out of the pump housing. If there is a rubber O-ring on the tube it should be replaced.
