Dash Knobs
Old 09-04-2014, 01:21 PM
Shadowrider123's Avatar
Shadowrider123
Shadowrider123 is offline
Dash *****
1964 F100
I bought a new vent cable pull.
The **** they sent me is a C1TZ-9700. It has a threaded end, the cable is a push on. What **** do I need?
Is the vent **** the same **** as the wiper switch? I need one of those too.
I have two pulls under the dash for the heater. The right **** has an insert that says heat, there is no insert on the left ****. Are those inserts available?
Old 09-04-2014, 02:17 PM
TA455HO's Avatar
TA455HO
TA455HO is offline
Originally Posted by Shadowrider123
1964 F100
9700 is choke cable. They must have sent you a choke ****.
Wiper **** is base part number 17513. For 1964 F100
C1TF-17513-A - Windshield wiper control - black plastic with white center
Try Dennis Carpenter if NOS isn't critical
Windshield Wiper **** | Dennis Carpenter Ford Restoration Parts
The "HEAT" and "TEMP" inserts are not reproduced as far as I know. Only hope on those would be NOS or used.
Vent **** is plain insert. Chrome bezel says "AIR". You could use a **** that has a set screw built in. Not sure if they reproduce those or not.
A bit rushed for time, but I'll try to research the vent **** a bit more and see what I can turn up.
Are you just replacing a cable on the drivers side?
Old 09-04-2014, 05:15 PM
Shadowrider123
My 66 did not have the cables so I didn't know what I needed.
The 64 had a left cable that worked but didn't look nice. I had a hole on the right side.
I ordered two cables.
When I removed the left cable I saw that the dash hole was much smaller than the right hole. Turns out the right hole isn't for the vent cable, the PO had something else there.
I replaced the left cable and then "refurbished" the old bezel/****, cut the cable off, used a fender washer, and filled the right side hole with a dummy cable.
I have a couple other problems, I need to post a pic.
Old 09-04-2014, 05:29 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No such thing, choke **** only furnished with the cable.
Ford did not sell the inserts by themselves, were only furnished with the *****.
These two ***** were only used with the deluxe fresh air heater...cables attach to a bracket...located under the dash to the right of the steering column.
Both ***** are obsolete, not reproduced, AFAIK
1961/66 F100/1100 / 1963/69 N/NT500/1000 / 1967/69 F800/1000:
C1TF-18534-A .. HEAT Control **** / Obsolete
IMMEL MOTORS in Fredericksburg TX has 1 = 830-997-2129.
POECS PARTS in Erie PA has 2 = 888-864-9305.
C1TF-18534-B .. TEMP Control **** / Obsolete
GRIESEL MOTOR CO. in Okarche OK has 1 = 405-263-7242.
ANTIQUE AUTO SUPPLY in Arlington TX has 1 = 817-275-2381.
C1TZ-8101890-B .. Right & Left Air Vent Cable-includes **** (**** not sold by itself) / Obsolete
1961/64 F100/1100 / 1963/69 N/NT500/1000 / 1965 F100/250 4WD / 1965/66 F350/1100 / 1966 F250 4WD / 1967/69 F800/1000:
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 291 = 800-476-9653.
Old 09-04-2014, 07:10 PM
Shadowrider123
I bought the cable from DC and the **** was not included.
DC is sending me **** C1TZ-17513. They say it will work on both the vent cable and wiper switch.
Old 09-05-2014, 12:25 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
Oh, so when you said "They" you weren't necessary talking about Ford? Oh, you didn't even mean Ford at all. Ya, I got that. Lol.
What he lacks in social skills he makes up for in mensa points. Don't let him bother you.
Old 09-06-2014, 06:23 PM
Macs1964F100's Avatar
Macs1964F100
Macs1964F100 is offline
1964 F100
Dennis Carpenter has the inserts. They are a couple bucks but shipping is $10 for orders under a $100 so you will want to order something else you need.
Old 09-06-2014, 08:20 PM
Shadowrider123
I have the plain inserts, I was inquiring aout the inserts that have heat and temp on them.
I don't even know how that system works, my 66 didn't have the two cables under the dash.
Old 09-08-2014, 08:11 AM
svolpone's Avatar
svolpone
svolpone is offline
can i hijack this thread and ask a question about these *****? How do you take the dang things off without breaking them? I'm worried that the PO super glued them on.
Old 09-08-2014, 11:36 AM
daveengelson's Avatar
daveengelson
daveengelson is offline
***There's the type of **** that slides onto the shaft and locks in position by a concentric clip inside the ****. Being very gentle, there's a small opening on the underside of the **** and using a 'mini' type screw driver; or something similar, insert the tool into this slot thus releasing the tension; it should not require any pressure, usually just by inserting the tool the **** should come right off; if not, then gentle move the tool towards the seat and the **** should come off?? These old ***** tend to get brittle so suggest use a tool that is flat and small that will fit into this 'slot' and do not use force or likely damage the ****?? This is a sad attempt to explaining how to remove, if there's a spare one can look at this clip and the procedure would be perfectly clear.
The headlight switch: **** and shaft are 1 piece, there's a button on top, occasionally bottom, of the light switch one needs to depress while pulling the unit out. To install just insert the shaft/**** in to the switch.
The original vent and chock cables on my 65 come as a unit, not sure about aftermarket replacements, may have to purchase separate???
Old 09-08-2014, 02:28 PM
NumberDummy
As original:
The headlamp switch **** & shaft is a one piece assembly. Depending on the year/serial number, there are two different shaft lengths: One type is 2 1/4" long, t'other is 3 3/16" long.
The wiper switch **** was furnished by itself, it's retained to the switch w/a #8 -32 headless set screw.
The lighter **** was only furnished with the element. The choke cable **** was only furnished with the cable.
The heater blower switch **** was furnished by itself, it's the same as the wiper switch ****.
Optional deluxe fresh air heater has two cables attached to a bracket, located under the dash to the right of the steering column. The two ***** (Heat & Temp) were furnished by themselves.
If so equipped, the air vent ***** were only furnished with the cables, which are the same right/left.
Old 09-08-2014, 03:49 PM
Shadowrider123
The two ***** I was sent screw on, they have a threaded insert in them.
What do they fit?
Old 09-08-2014, 04:56 PM
NumberDummy
C1TF-17513-A .. Wiper & Heater Switch ****.
Mearntain
13
07-08-2019 12:56 PM
clinkfield
07-28-2013 08:14 PM
williamwilliam
06-04-2011 05:07 PM
ocbp1981
02-22-2011 11:21 PM
deyomatic
12-30-2009 05:39 AM
Quick Reply: Dash Knobs
