Fuel Injectors? Clean? Replace? Cheap? Expensive?
Yep….
I've seen the post on cleaning the injectors… sounds pretty good. Aftermarket new units range from $15.00 to $50.00 each… there has to be some difference in the quality for that wide of a price range. Just looking at the pix on Rock Auto you can see some use lots of plastic and some use stainless steel.
I'm going to take a look at my two local parts houses to get a hands on feel for 'em… maybe I'll just clean the ones that are in the engine.
I'm not having any problems but I think this truck has the originals in it and I'm in a preventative maintenance mood right now. I want to get as much done to this truck as i can the next few days… I have to do a little bit more reassemble work on the wife's Miata (it's for sale) and I have to get the stock car out of the shop as I have a Jeep engine to tear down and fix...
I took my 5.8L apart to find fault causing a dead miss in two cylinders, thought sure couple of the injectors had thrown in the towel due to age (1994).
I got the upper intake off made up a test harness so I could power them with a 9 volt, section of rubber hose from blow gun to injector. I couldn't find a thing wrong with them, turned back to the truck and its engine harness. Trucks sits for most the summer in the field, found rodent damage to those two injectors the red wire bit through.
In a way made me mad was looking for a reason to put a new set in, I cleaned them up tested them make sure they created a spray pattern and fully closed, found they all did so. I ended up putting them back in replacing the engine harness instead.
I was hoping to find fault in them, a solid reason why new injectors would eek out little better fuel econ, could see I was better off saving money would pay for new injectors to pay for fuel instead!
460 is easy to pull and check them, no upper to remove first, if you have the time it wouldn't hurt to check them over get a kit for each one, as stated the kit isn't very expensive and new o rings on em is always a good thing.
A half inch copper fitting brush is the perfect thing to use for cleaning the injector sockets in the intake and the fuel rail, that and a shop vac.
Chevy_Eater
25
09-10-2017 10:31 PM
GammaDriver
02-04-2007 10:48 AM
