Modular V10 (6.8l)
cleaning injectors
Old Jun 18, 2012 | 08:54 AM
VONxRUBENxLA's Avatar
VONxRUBENxLA
cleaning injectors
whats the best way to clean fuel injectors?
Old Jun 18, 2012 | 01:03 PM
dusted4eva's Avatar
dusted4eva
Here's a cheesy vid , looks interesting.
How to clean fuel injectors in your car. - YouTube
Old Jun 19, 2012 | 08:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Buy new ones?
Old Jun 19, 2012 | 08:32 AM
VONxRUBENxLA
Originally Posted by Krewat
Buy new ones?
That's the best thing huh??
Old Jun 19, 2012 | 08:40 AM
krewat's Avatar
krewat
Personally, I've never had dirty ones, and anyone I know that's had it done has never said it did anything. Either there was no improvement, or the mechanic screwed something else up along the way, or came up with some other reason for the owner to spend $'s on something he noticed while in there.
Is there a reason you want to do it?
Old Jun 19, 2012 | 10:48 AM
dusted4eva's Avatar
dusted4eva
WHE
Personally I have never cleaned any injectors or replaced. I use Amsoil PI once in a while if I suspect dirty injectors. Just my preference and I'm not going to get into a debate over a product. It works for me. If anything a warm fuzzy feeling that I did attempt to address the problem.
AMSOIL - P.i. Performance Improver (API)
Old Jun 19, 2012 | 10:58 AM
krewat's Avatar
krewat
Yeah, I'm not against using injector cleaners you put in the gas tank. Can't hurt, and I've done it once in a while just "because"...
But most of the gas around here has detergents in it, and has 10% ethanol which will clean just about anything out anyway
Old Jun 19, 2012 | 11:34 AM
dkf's Avatar
dkf
Chevron Techron in the gas. I don't baby the truck, am not afraid to get on it and bring the rpm up. IMO that helps to keep carbon and gunk at bay along with a cleaner every now and then.
Old Jun 19, 2012 | 04:20 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Ditto on the Chevron Techron once in a while. Good stuff. Most brands of gas, ie Chevron, Shell, BP etc, are offering some sort of fuel system cleaner in the the gas. Just run some name brand gas through your engine every few tanks to maintain clean injectors.
Old Aug 8, 2012 | 10:54 PM
NastyNateDog's Avatar
NastyNateDog
What I did was to let them soak over night in injection cleaner. But it was a good thing i pulled them 2 of them had cracked hats and one looked like crap.
Old Aug 9, 2012 | 06:25 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Nate, How many miles "did" you have on your injectors? Did you have any symptoms?
Old Aug 9, 2012 | 10:42 AM
toddb1's Avatar
toddb1
I think it's pretty pointless to clean them. The tolerances in the injector are so tight that if something were to get in it's going to be stuck open or closed. The only thing you're cleaning is the filter, if that is dirty the discharge pattern and flow won't be very good. I rebuilt mine after the o rings started falling apart, I got the kit from mr injector.com, filters/orings/pintle caps and it was pretty easy to do.
Old Aug 10, 2012 | 05:29 PM
NastyNateDog
Well the truck has 233k and the reason was a last resort for a bank 1 running lean code and I decided to check them all out and replaced the ones that looked bad.
Old Aug 15, 2012 | 03:29 PM
pappy19's Avatar
pappy19
I run Sea Foam every 20k and seems to do a good job. I do use Chevron alot but not always. Costco now has a cleaner in their gas and I fill up there when I have a chance.
jimbo1969
Jul 27, 2016 09:16 PM
FordOwnerJoey
Jan 21, 2014 09:21 PM
j250hd
Aug 23, 2011 10:27 PM
