Fuel injectors - 4.0L
Old Jul 16, 2005 | 03:08 PM
rusty70f100's Avatar
rusty70f100
I've been having a mileage issue with my '92 Exploder, and have traced it down to leaky injector(s). I would like to replace them, but the auto parts stores all want at least $75 per injector. Jegs has Accel fuel injectors for half that. Problem is, they're not application specific. So here comes the question:
What is the stock flow rating for fuel injectors for a 4.0L V6 in a '92 Exploder? I'm kinda thinking it was 19lbs/hr, but it'd suck to screw this up, so I'm asking.
Old Jul 17, 2005 | 05:32 PM
rusty70f100
For anyone who cares:
I looked it up on the Accel site, they were 21lbs/hr.
Old Jul 18, 2005 | 02:11 PM
1984 f-250's Avatar
1984 f-250
I think the stock injectors are 16 or 18. I wil check my book. Rebulding your injectors is even cheaper than buying new ones.
Old Jul 18, 2005 | 04:14 PM
rusty70f100
The difference is probably the way they're rated. I'm sure if the 21's are what Accel recommends, then they'll work fine. Probably some difference in the way they flow, or in the electronics somehow. I already have 'em ordered from Jegs, $205 for all 6 of 'em. Considering the stock rebuilt ones were $75 PER INJECTOR at the parts store, that's a smokin' deal. Pay less and get brand new injectors. Looks good to me!
I'll let everyone know how they work. Should be here tomorrow.
Here's a link to the Accel information.
Old Jul 19, 2005 | 03:02 PM
1984 f-250's Avatar
1984 f-250
A review on those would be great!
Old Jul 19, 2005 | 03:19 PM
rusty70f100
You'll get your review... eventually.
<rant>
They're on backorder. I hate backorders. Should be a week. I ordered overnight shipping for a reason. You'd think they could keep 'em in stock. Morons...
</rant>
But yeah, you'll get your review!
Old Jul 29, 2005 | 02:51 PM
rusty70f100
Ok, I got 'em, they're in. They come in a neat box that says Accel on it, individually boxed, with little plastic caps over the ends.
Installation is fairly straightforward.
1. Remove everything from upper intake, keep it all in order, remove nuts that hold down upper intake from their studs, pull upper intake.
2. Remove wires from existing injectors.
3. Remove studs with special torx socket (had to go buy one).
4. Remove fuel injector plate, it just pulls up.
5. Get a (clean!) screwdriver and remove old O-rings that were left in the fuel injector plate by the old fuel injectors. Stick them back on old fuel injectors.
6. Pull out old fuel injectors. They can be stubborn. Put some back muscles into it.
7. Prep new fuel injectors by coating the rubber O-rings with a light coat of grease, like wheel bearing grease. It helps 'em go in easier. KEEP THEM CLEAN!!!
8. Push new fuel injectors into the lower intake. It helps to rock them back and forth a little. Be careful to not knock any loose dirt down into the intake. It's impossible to keep it all out, but keep the amount to an absolute minimum.
9. Connect the new injectors to the wiring harness.
10. Go get a friend to help position the fuel injector plate, while you try to position 6 fuel injectors, and a gasket, all at the same time. Be sure to use a new gasket between the injector plate and the upper AND lower intake. It takes two, one on each side.
11. The injector plate should be almost touching the gasket when the injectors are installed right. You can thread in two of the studs to help position the plate and keep one end from coming up. Reach under and feel to make sure the injectors are all in their places before tightening down the studs. Tighten down the studs with the torx socket.
12. Place new gasket on top of the injector plate, and place upper intake on. Torque down the nuts that hold it on.
13. Reconnect all the stuff to the upper intake, throttle body, vacuum hoses, everything.
14. Go run it, check for fuel leaks.
Notes: When I say remove, I mean remove enough stuff from the assembly that you can swing it out of the way. The injector plate is a good example. You dont need to disconnect fuel lines, just swing it out of the way to get to the fuel injectors. Also, on the studs that hold the injector plate and upper intake down, it helps to use some moly grease on the threads so you get an accurate torque reading.
Results: I've only driven it about 20 miles, but I have noticed some results. It runs smoother and starts quicker. Whereas before it took about 5 seconds of cranking to start it, now it takes less than 1 second. Turn the key and it's going. I havent driven it far enough to determine gas mileage, so that remains to be seen. I'll post again later with some results.
Sorry for the book, but a review was requested!
carey965
2004 - 2008 F150
24
Apr 1, 2022 08:17 PM
Dan92
Feb 22, 2017 03:14 PM
wr310rdr
Jul 26, 2014 11:58 AM
smitty403
Mar 10, 2014 03:24 PM
ltlvt
1983 - 2012 Ranger & B-Series
Sep 27, 2013 08:54 PM
