Having transfer case problems.. no lights on dash, (except when starting), not engaging..(4X or 4XLow), no voltage to transfer case motor..Checked all the fuses..Cleaned both connectors on transfer case.. switched the relays under the hood.. Want to check ESOF switch.. How do you remove the switch from the dash ?
I don't know if all the switches are the same, but on my 2000 just slip a knife in under the black bezel that the switch sits in and pry, there's 4 snap in tabs one at each corner of the bezel.
Then from the back the switch itself is screwed onto the bezel.
4 push in tabs. they are on the sides at the top and bottom. trying to uplaod a pic but i'm at the lake and service is spotty and slow. mines a 2000 xlt.
OK.. I am bench checking this 4 prong ESOF switch.. With an ohm meter (20K scale), the two outside lugs has continuous continuity in all positions of switch.. Between the two center lugs .. each mode respectively, 3.9K ohms, 1.1K ohms, 360 Ohms. Sound about right?
OK.. I fixed the problem with the ESOF not working.. Ending up buying a new shift motor assy and it works great now..Good price on Amazon.com with free shipping !
If you exercise the solenoid one a month I have found the failure rate is almost 0.
I had an issue back in the late 70's where one failed. The mechanic who replaced it told me to put it in Low, High, Off once a month. I've not had an issue since on any of my vehicles..
I completely agree with exercising anything mechanical as you say.. Good point. I will try and remember to do that.. thx
