Where does electronic transfer case get pwer from?
Old Dec 30, 2007 | 11:26 AM
matty169's Avatar
matty169
1999 F-350 is stuck in 4-Lo. 4x4 and 4 Lo lights are on and the dash switch has no effect. When I switch the dash switch we get no power to the T-case shift motor. Fuses are good. Tried a known good switch and that wasnt it. What is between the fuse, the dash switch, and the t-case shift motor? Thanks
Old Dec 30, 2007 | 12:19 PM
JLDickmon's Avatar
JLDickmon
I'd have to look to be sure, but I think the GEM actually controls it...
did you check the fuses in both fuseboxes?
JLDickmon's Avatar
JLDickmon
oops... double clutch
