53 f100 crown Vic front end
Old 08-23-2014, 09:47 PM
DasHaas's Avatar
DasHaas
DasHaas is offline
I'm at the point on my build where I need to address the frame and suspension. Not sure what to do for the rear yet but I'm looking to put a crown vic front end in my truck. Any suggestions on what year to look for or stay away from? I have also noticed That the crown Vic front ends have engine mounts, does anyone know if these mounts will match up with a 302 block?
Old 08-24-2014, 01:01 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1979/2002 LTD/Crown Victoria/Grand Marquis have worm and roller steering.
2003/2011's have rack and pinion steering.
Crown Victoria name replaced LTD in 1982.
Old 08-24-2014, 07:51 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
2003 and up have an aluminum crossmember. Name:  image.jpg
No cutting of the frame involved, but there is a little fabrication and a bit of welding.
Old 08-25-2014, 03:23 PM
DasHaas's Avatar
DasHaas
DasHaas is offline
Thanks guys, this definitely seems like the way to go, but do you know if a 302 will fit on those motor mounts?
Old 08-25-2014, 04:27 PM
bjmayberry2
I'm sure someone has done it but the 302 is narrower than the 4.6. Sooo looks like you may need to make some sort of motor mount adapter.
https://www.fordracingparts.com/down...Dimensions.pdf
Old 08-25-2014, 05:44 PM
Scot's Avatar
Scot
Scot is offline
Yes I am running a 302 on the stock square mounts. I used a donut mount on top and a 1/4" triangular mount on top bolted to the stock 302 mounting holes.
Old 08-25-2014, 06:58 PM
clintonvillian's Avatar
clintonvillian
clintonvillian is offline
A little time and you can make a really attractive suspension:
Old 08-25-2014, 07:54 PM
dynamic's Avatar
dynamic
dynamic is offline
Originally Posted by bjmayberry2
2003 and up have an aluminum crossmember. Attachment 104532
Hey those are some nice photos u have there.
Old 08-25-2014, 08:17 PM
bjmayberry2
Humm wonder where they're from.
Old 08-25-2014, 09:40 PM
DasHaas's Avatar
DasHaas
DasHaas is offline
Thanks for the info @scot! Do you have any reference pics or links to the adapters you used?
Old 08-25-2014, 09:41 PM
DasHaas's Avatar
DasHaas
DasHaas is offline
@clintonvillan.. That looks absolutely beautiful! Very clean work!!
Old 08-26-2014, 06:09 AM
dynamic's Avatar
dynamic
dynamic is offline
Here are some shots of the welding required....
Old 08-31-2014, 03:33 PM
Scot's Avatar
Scot
Scot is offline
I think these mounts came from an early 90's 5. 0 Cougar but don't remember for sure. Yes, my shop sort of looks like a dumpster...
<a href="http://s270.photobucket.com/user/nozzleman201/media/z2photo.jpg.html" target="_blank"><img src="http://i270.photobucket.com/albums/jj105/nozzleman201/z2photo.jpg" border="0" alt=" photo z2photo.jpg"/></a>
<a href="http://s270.photobucket.com/user/nozzleman201/media/z1photo.jpg.html" target="_blank"><img src="http://i270.photobucket.com/albums/jj105/nozzleman201/z1photo.jpg" border="0" alt=" photo z1photo.jpg"/></a>
Old 08-31-2014, 05:00 PM
clintonvillian
Did any of you fellas happen to measure the center distance between the two studs on the lower control arms?
Latroca52
01-04-2016 04:58 PM
Hughmullersa
08-30-2015 03:21 AM
millertme
07-23-2014 09:38 AM
tylordurben
45
06-07-2009 02:51 PM
Quick Reply: 53 f100 crown Vic front end
