Should I change my trans fuild?
Old 08-24-2014, 08:24 AM
Backwoods351's Avatar
Backwoods351
Backwoods351 is offline
It's ok Hoot, this is all good info and I much appreciate everyone's question's and answers.
  #32
Old 08-25-2014, 06:43 PM
Backwoods351
Hi guys, I went ahead and replaced the fuild,filter, and cleaned the vss. The trans is doing great. it shifts smooth now with no problems. Thanks everyone for posting on this.
  #33
Old 08-25-2014, 07:34 PM
Backwoods351
This was right after I took the pan off. It was cleaner than I thought it would be.
After I cleaned the pan
Pic of the inside's
  #34
Old 08-25-2014, 09:04 PM
HOOTs95PSD's Avatar
HOOTs95PSD
HOOTs95PSD is offline
Glad it is doing OK. Mine will get its fluid changed next weekend most likely.
  #35
Old 08-30-2014, 04:32 AM
HOOTs95PSD's Avatar
HOOTs95PSD
How many quarts does it take after dropping the pan?
I think it is 7 quarts from the torque converter.
I bought 4 gallons of fluid just want to make sure there is enough on hand as I usually do these things after hours and I also have NO back up vehicle running right now to go get more stuff.
I have a new extended pan for it. A new filter and a new re-useable gasket going in.
On a side note , has anyone had any experience with a Gear Vendors over drive unit for these? I have 2 very long road trips on the horizon and would pay off a lot of it just with those two trips. This truck is also going to be my daily driver for the next year or so. Hopefully it goes back to just camping and 4 wheeler hauling trips after that.
  #36
Old 08-30-2014, 05:13 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
Four gallons of fluid on-hand is MORE than enough. Service manual states to refill with 6.5 quarts through the filler tube, and add 0.5 pints at a time to reach the proper level.
granny_rocket
05-10-2015 04:49 PM
BiggDogg77
01-30-2013 07:01 AM
midnight1967
07-14-2007 10:05 PM
bill99psd
15
02-23-2007 09:35 AM
bluebird
17
07-09-2006 04:29 PM
Quick Reply: Should I change my trans fuild?
