79 f150 Starting problem
Old 08-15-2014, 01:32 PM
ford4her's Avatar
ford4her
ford4her is offline
Question 79 f150 Starting problem
Hi all ,.. My 79 f150 4x4 automatic starts great and runs strong, but if I stop anywhere and turn it off it won't start again. It is completely dead, no clicking no nothing. The only thing that lights up is the red seat belt light in the dash. This has happened the last two times at the gas station. It eventually does start again after wiggling the tilt lever/blinker and shifting in and out of Park. Why is this happening ?
Old 08-15-2014, 06:53 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
More than likely you need to adjust your NSS (neutral start switch).
On the '79 model it should be on the side of the transmission.
Put the transmission in neutral, loosen the two retainer screws and insert the drill (or paper clip, etc.). Once the drill bit goes all the way in, tighten the screws.
While you're under there, look for wear in the linkage, especially the little stud that attaches the shift rod to the shift arm on the trans.
SIRed
1978 - 1996 Big Bronco
01-16-2011 07:24 PM
starweb
10-19-2009 08:20 PM
roosterst
03-24-2009 10:47 PM
Terran
09-13-2005 01:38 PM
IowaTower
12-21-2004 04:11 PM
Quick Reply: 79 f150 Starting problem
