1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
05 brake job. Sticking brakes.
Old 08-14-2014, 10:21 PM
Ford'05HG's Avatar
Ford'05HG
Ford'05HG is offline
Howdy fellas. The 05 is needing a brake job now all around and I'm considering doing it myself. However I have a rear brake on the drivers side that sticks. A lot.. I've never done brakes on this one myself but I understand the basics. Never bled brakes either.
So, what are you guys running for "upgraded" brakes and how can I go about solving the sticking for my truck?
Also the brake fluid is the original 194,xxx mile brake fluid so I thinking its time to flush.
Old 08-15-2014, 11:18 AM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
The sticking brake is a bad caliper, either because the piston inside of it is hanging up, or because it's leaking fluid. If you find you have to change one side you should change both sides to maintain even braking.
Old 08-15-2014, 12:58 PM
Ford'05HG's Avatar
Ford'05HG
Yeah. I'm gonna put new everything so they all wear the same. I'm looking for a little more stopping power this time though as I may be adding a few turbos to this truck sometime in the future.
Old 08-15-2014, 06:24 PM
fred_79f250's Avatar
fred_79f250
fred_79f250 is offline
I know you said sticks "a lot" - but FYI - I have sometimes found a frount brake on my '00 XP that felt "sticky" and running warm - hard to turn the wheel by hand with it lifted. I found that the culprit was in fact the pads sticking on the sliders. I mean, really stuck. Sure, the hydraulics of the caliper could press them in to stop, but then they would stick there, coming off the rotor only as much as sheer force pushed them.
Old 08-15-2014, 06:30 PM
cgrutt's Avatar
cgrutt
cgrutt is offline
I'm not a mechanic and the advise above is probably right, but I had an '02 Explorer that had rear driver brake sticking and it was the emergency brake. Dealer fixed it, so I don't know what was involved, but just wanted to point out another potential cause before you go out and buy calipers.
Old 08-16-2014, 09:13 AM
Ford'05HG's Avatar
Ford'05HG
Thanks. Ill keep these thoughts in mind.
Old 08-17-2014, 12:18 PM
alloro's Avatar
alloro
alloro is offline
Good thought but keep in mind that with these vehicles the e-brake uses a completely separate set shoes and has nothing to do with the regular braking system, calipers, or pads. I don't know if the explorer is like this or not.
Old 08-17-2014, 02:54 PM
cgrutt's Avatar
cgrutt
cgrutt is offline
I understand that. It was still the cause of my driver rear brake sticking. The e brake is a drum style brake on inside of rotor. I only mentioned because it may not be problem with normal caliper.
dwstenersen
01-09-2017 01:46 PM
MPDano
11-15-2012 11:11 AM
leebrown5
15
09-29-2011 01:47 PM
lowcountry
2004 - 2008 F150
01-03-2007 08:37 PM
7 VII 7
01-16-2006 04:41 PM
Quick Reply: 05 brake job. Sticking brakes.
