Braking Components
Old Jan 14, 2006 | 01:58 PM
7 VII 7's Avatar
7 VII 7
Braking Components
Hey guys, my gfs 1999 Ford Explorer v6 needs new brakes. Where can I get some rear and front brakes.. and what kind of braking fluid does it take? DOT-3?
Thanks guys!
Old Jan 15, 2006 | 01:48 PM
marragtop's Avatar
marragtop
You can get brakes at any auto store. The question is... what type of brakes will you get. I wouldn't get anything less than semi-metallic. Don't forget to get the anti squeal lube..
Old Jan 16, 2006 | 08:25 AM
7 VII 7's Avatar
7 VII 7
Fluid
I am looking for brakes for under $40 for the front, and under $40 for the rear. GF is on a tight budget.
Also what kinda of brake fluid does her car take?
Old Jan 16, 2006 | 08:55 AM
autoparts's Avatar
autoparts
Former Vendor
Low Cost Brake Pads Available at RockAuto.com
www.RockAuto.com carries brake pads starting at about $12 a set. We also have loaded (pads installed) brake calipers, rotors (starting at $11) and the other brake parts you might need.
DOT 3 is the only brake fluid I have ever heard Ford recommend. Ford's Motorcraft says their brake fluid meets DOT 3, SAE J1703 and FMCVSS 116 specifications. www.RockAuto.com does not sell chemicals, but DOT 3 brake fluid is available everywhere; even grocery stores.
Good luck with your brake job!
Old Jan 16, 2006 | 04:41 PM
micgang's Avatar
micgang
I have used rockauto a couple of times now and they do have great prices on brake parts, even after shipping. Plus they often have 5% discount codes... like this one
359217246149
I recommend the Raybestos semi-metallics for your vehicle...
MT4x4guy
Sep 16, 2013 01:04 PM
'94IDITurbo7.3
Aug 25, 2012 06:08 PM
Diesel Reaper
Apr 25, 2012 08:47 AM
gthiboy
Mar 20, 2011 01:31 PM
nikesb1111
Feb 17, 2009 06:19 AM
