460 smoking under deceleration
Old 07-31-2014, 07:57 PM
bludog's Avatar
bludog
bludog is offline
I have a 1993 ford f-350 crew cab 4x4 5speed 181,xxx miles oil change every 3,000 miles since new. When I am deceleration it puffs smoke. If I hold the throttle open just a hair it doesn't smoke. It does not smoke any other time. No smoke at idle or wide open. runs great engine runs very smooth and quite. No blow by I am thinking its the valve seals Since it does it under high vacuum. I was going to replace the valve seals this weekend should I or am I wasting my time.
Old 07-31-2014, 08:09 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
Sounds like the seals with that mileage and how easy it is to do just throw some new seals in and see if it stops.
galaxy S4 using IB AutoGroup
Old 07-31-2014, 08:40 PM
bludog's Avatar
bludog
bludog is offline
I would think if it was sucking it up past the rings it would have blow by.
Old 08-01-2014, 10:28 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Valve stem seals......
Old 08-01-2014, 12:05 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
x4
You might want to check for sloppy guides while you have the springs and keepers off.
Old 08-02-2014, 08:17 AM
bludog's Avatar
bludog
bludog is offline
I put valve seals in the drivers side they all looked good. When I got to the passanger side I noticed all the plugs had crusty dried up oil on them and the #6 cylinder has 25 psi. What can go wrong in one cylinder and cause one side to burn oil? the drivers side plugs are clean.
Old 08-02-2014, 08:20 AM
bludog's Avatar
bludog
bludog is offline
I'm going to check the compression again. It was getting late last night I could have not done something right. also what is strange the truck never missed idle perfect.
Old 08-02-2014, 08:23 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
#6 is the second plug on the drivers side...
If the passenger side has more sludge it is likely because fresh air is drawn in through the filler and the PCV is bringing vapor up through the passenger valve cover.
Glad you are going to check again.
25 psi is bad, very bad.
Last edited by ArdWrknTrk; 08-02-2014 at 08:38 AM. Reason: did not see reply in time
Ben34
3.8 & 4.2L V6
03-28-2007 10:55 AM
michaelbrainardatwor
11-17-2006 07:25 AM
CheaperJeeper
32
10-18-2006 10:50 PM
Lizard94
02-02-2003 09:31 AM
zimman20
11-14-2002 01:24 PM
Quick Reply: 460 smoking under deceleration
