removing the parking brake cables
Old 08-02-2014, 02:46 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
I'm working on my 96 today. (painting the rear half of the frame, etc.)
The parking brake cables are an annoyance. I never have used them, and never will use them.
Can I just remove (cut) them with out taking the drums apart?
Old 08-02-2014, 06:49 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
I wouldn't just cut them. The issue is that the cable itself could come loose from the emergency brake lever and get loose inside the drum. I suppose you could remove the rest of the cables if you could somehow retain pressure on the inside cable so it didn't get loose, but the best thing would be to just replace them and get your e-brake working. With the frequency that these trucks loose their vac pumps, it wouldn't be a terrible thing to have them functional just in case.
Otherwise, I guess I would just leave them alone.
Old 08-03-2014, 04:43 PM
cowmilker08
Well, darn, you talked me out of it.
95f2504x4
06-11-2012 09:30 PM
ptaylor-01
1997-2006 Expedition & Navigator
04-22-2010 04:04 PM
subyellow07
1983 - 2012 Ranger & B-Series
11-06-2009 08:28 PM
bad_habit59
02-12-2009 12:20 PM
mikey11211
08-18-2006 09:12 PM
Quick Reply: removing the parking brake cables
