E brake cables
Old Jun 11, 2012 | 08:55 PM
95f2504x4's Avatar
95f2504x4
E brake cables
Hey been a while since I've been on here but I'm at another standstill on my truck. 92 f150. Trying to take off the e brake cables at the differential. What is the easiest way to get them off the diff? Right now the trucks frame is up on blocks and the rear diff is off the springs, wheels still attached. Only thing holding me back from taking the diff out from under the truck is the brake cables. Any advice would be great.
Old Jun 11, 2012 | 09:08 PM
PatsPOS's Avatar
PatsPOS
You're probably not gonna like this much, but short of cutting the cables, you're gonna have to take the wheels and brake drums off. Take the shoes off, and then you can remove the parking brake hardware from the cable. Once the cable end is free, get a ½" combination wrench and use the box end to compress the spring clip that holds the cable sheath into the brake backing plate.
I sometimes have a hard time explaining things, but once you get the drum off, it should be pretty self-explanatory.
Good luck,
Pat
Old Jun 11, 2012 | 09:18 PM
95f2504x4's Avatar
95f2504x4
Kinda what I figured I was going to have to do just wanted to make sure. I'm pretty much rebuilding the whole truck so depending on how I feel tomorrow will determine how I get them off. Cutting and replacing them or taking them off the right way and using them later........
Old Jun 11, 2012 | 09:22 PM
slamed150's Avatar
slamed150
a small piece of 1/2" conduit works well also. to compress the little fingers
Diesel_Brad's Avatar
Diesel_Brad
Unhook them at the spreader bar and take the cables with the axle
Old Jun 11, 2012 | 09:30 PM
slamed150's Avatar
slamed150
or this !!
csb41502
17
Jan 11, 2015 06:43 PM
cowmilker08
Aug 3, 2014 04:43 PM
grumpy hvacr
1983 - 2012 Ranger & B-Series
Jan 30, 2011 01:44 PM
bad_habit59
Feb 12, 2009 12:20 PM
MikeGV
Feb 6, 2005 09:43 PM
