Front Parking Brake Cable
Old Nov 6, 2009 | 10:48 AM
subyellow07's Avatar
subyellow07
Question Front Parking Brake Cable
Hey everyone,
I am having the hardest damn time removing/installing the front parking brake cable on my 2003 Ford Ranger to the parking brake pedal assembly. Is there a trick I do not know about?It looks like I should just be able to slide it over and pull it out but that doesn't seem to be the case.
Thanks for the help!
-AJ
Old Nov 6, 2009 | 08:28 PM
g_k50's Avatar
g_k50
Release the parking brake
Pull down on the brake cable under the cab, at the same time insert a 4mm drill bit or equivalent in the parking brake control.
Remove the Lh front fender apron
Disconnect the front parking brake cable and conduit at the locating hole end of the connector Disconnect the front parking brake cable and conduit from the parking brake intermediate cable.
Remove the front parking brake cable and conduit fromt the bracket, Compress the retainer from the front parking brake cable and conduit from the bracket, Remove the front parkling brake cable and conduit from the bracket.
Remove the parking brake release mounting bolts
Remove the parking brake signal swithc electrical connector
Remove the three bolts holding the parking brake control unit.
Disconnect the front parking brake cable from the parking brake control
Compress the front parking brake cable and conduit-to-parking brake control clip
Remove the front parking brake cable and conduit housing
Installation is the reverse, make sure that the cable is routed through loop on takeup spool.
tsbrewers
Dec 7, 2024 03:25 PM
blueoval65
Mar 3, 2017 01:30 PM
blueoval65
Jan 18, 2017 01:19 PM
KillerTux
Aug 13, 2011 11:01 PM
