51 F1 rear spring replacement
Like Merc said, 500 lbs is nothing in the back of one of our trucks. Put two fat chicks in the bed as a test run, Lol.
You probably have a couple broken leaves on the low side. It's not a pleasant job to replace the springs (always replace in pairs), but you can do it yourself. Assume that you'll find that you need new pins and bushings, new U-bolts. You can also assume that at least one pin will be a PITA to get out. U-bolts shouldn't be re-used.
You need to find two static points on the rear frame horns and measure from there. Way too many variables out to the fenders. Even a bed mount bolt that is overtightened (or loose) can cause enough flex to cause the kind of deviation you're describing.
To add to Ross's post about the replacement pitfalls, you'll also need to drill an access hole in each side of the frame crossmember inorder to be able to drive the front shackle pins out.
If you ask me, it's easier to remove the rear springs with the bed off the truck, unless you have a lift.
https://www.ford-trucks.com/forums/6...l#post12066882
GreatNorthWoods
07-11-2008 06:11 AM
FLUSHED UP
04-27-2007 09:54 AM
Christopher2
08-16-2004 09:45 AM
