Wheel bearing measurements needed.
Got a good deal on some wheels; and wanting to up grade to front disc on a 64 F100; the only problem is that the front wheel lug pattern is 5 on 4 1/2. The wheels where on a 54 F100; so I need measurements that are from said 51 thru 56? I need to determine if the spindle bearings i.e. front inner & outer bearings will mate to a 64 front axle spindle. Bottom line need inner bearing measurements for both bearings.
Thanks in advance.
Thanks in advance.
abe
51
04-10-2019 04:53 PM
