trans / rearend question
Old 07-29-2014, 06:46 PM
mcali2's Avatar
mcali2
mcali2 is offline
OK i have a 59 f100 2x4. it had the 292 v8. the rear end is stock as far as I know and does not have the gearing tag on it. I have a new trans out of a 82 f350 that had a rear end with 4.53;1 r&p.. the original tire size was 215 85 16 I believe. What is the R&P for the stock f100 rear end? I am hoping it is like a 3:1 or near that so I can take the 3 speed with a granny and use it like a 4 speed.
Old 07-30-2014, 12:08 PM
nick5446's Avatar
nick5446
nick5446 is offline
Subscribing because I have a similar question. My 272, 4spd is comfortable on the highway at like 55, but I'd like to make that 65 if possible.
Old 07-30-2014, 03:54 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
Data plate in glove box will tell you what rear end you have. Prolly not a 3:1 Not too fuel conscious back then and not many highways nor would you drive your truck on one anyway. I just sold a 3:1 not long ago to a member here. Should be a number on data plate under the axle section. Middle right of data plate. Look up that number. I have 01 and I believe that translates to a 3.7:1.
You can also figure it out by counting drive shaft revolutions and tire revolutions while you turn either. Should be between 3 and 4 or more drive shaft to one wheel turn. Viola there is your ratio.
Clear as mud?
Old 07-31-2014, 09:50 AM
mcali2's Avatar
mcali2
mcali2 is offline
I believe my plate on the door jamb has 01 on it. I don't remember anything on the glove box.
I will have to test the gears I have and then maybe move to a 3.5:1 or 3:1
Old 07-31-2014, 06:23 PM
Damifiknow's Avatar
Damifiknow
If its a 01 I'm pretty sure its the 3.7:1 but look at my username.
Data plate should be on inside of glove box door. It least that's where mine is?
Old 07-31-2014, 10:30 PM
MARC's Avatar
MARC
MARC is offline
gear ratio
my 59 f100 4x4 with 292 has 3.89 ford rear end and 3.91 44f front axle.
Marc
Old 07-31-2014, 10:31 PM
MARC's Avatar
MARC
MARC is offline
duh....you wrote 2x4.....sorry
Marc
Old 08-01-2014, 06:39 AM
Walston's Avatar
Walston
Walston is offline
It should be a 3.7:1 unless someone changed it. Only way to know for sure is to pull the axles, drop out the differential and count the gears teeth
Old 08-01-2014, 09:44 PM
mcali2's Avatar
mcali2
mcali2 is offline
Well at least it will go faster and not slower.
Old 08-09-2014, 11:38 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Rating Plate located on the drivers side A pillar (windshield post) or on the inside of the glove box door.
twin me beam
12-13-2014 09:14 AM
raven3
01-01-2014 08:28 PM
skfinch
09-17-2006 12:39 PM
FORD352V8
12-02-2004 09:34 PM
ford89t
10-31-2004 01:38 AM
Quick Reply: trans / rearend question
