gear rato
Old Oct 31, 2004 | 01:15 AM
ford89t's Avatar
ford89t
gear rato
i have a 1989 ford F-350 with a steerling 10.25 rear axel who can i figure out its stock reag ratio
Old Oct 31, 2004 | 01:23 AM
85e150's Avatar
85e150
Ratio tag on one of the bolts on the rear cover?
VIN or codes on the VIN plate or spec plate inside a door sill?
Owner's manual to decode the plate?
Look for axle codes and post here, someone will know, and your post will probably be moved to the axle trans etc area.
Old Oct 31, 2004 | 01:38 AM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Not scientific, but used to work in my younger years.
1. Safely, raise the rear end up so the wheels turn freely. (Tranny in neutral)
2. Mark a spot on one tire and match it to the wheel well.
3. Mark a spot on the rear end of the drive shaft and match it with the closest part of the differential housing.
4. Spin rear wheel one full turn. Meanwhile, have someone count the number of exact times the driveshaft turns.
For example : driveshaft turns 3.5 times for one revolution of tire. Differential gearing is 3:50. You can usually guestimate pretty close if you know the gear ratios available.
Finding a tag is much easier and more accurate, though.
