Vapor Canister Vent Solenoid
Old 07-25-2014, 05:58 PM
garry11268's Avatar
garry11268
garry11268 is offline
Does anyone know where is the sensor for a 2006 Ford F150 5.4 Vapor Canister Vent Solenoid is located?
Old 07-26-2014, 12:41 AM
j.grif's Avatar
j.grif
j.grif is offline
I would think that it would be mounted on the canister itself, but it may be under the hood attached to one of the vacuum lines going into the intake, it may be located on the fire wall and possibly be called out on the vacuum hose diagram if Ford put the sticker under the hood, sorry I couldn't be more specific, You may get more answers in the 2004-2008 forum, good luck!
Old 07-26-2014, 07:45 AM
garry11268's Avatar
garry11268
Thank you very much. I will check under the hood and also post on 2004-2008 forum. Garry...
Old 07-26-2014, 09:40 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
The vent solenoid is mounted in the canister above the spare tire. The purge valve is under the hood next to the brake booster.
Old 07-26-2014, 10:43 AM
garry11268's Avatar
garry11268
Thanks, if of them is malfunctioning would that be the reason the check engine light is on? I had it checked by a garage they said it was a sensor related to my gas tank vent.
Old 07-26-2014, 12:06 PM
70f100longbed
What is the code?
Old 07-26-2014, 12:36 PM
garry11268's Avatar
garry11268
Took to Advance and the code was 0446. Thanks for your help..
oliebeme
01-16-2016 01:46 AM
pipman76
05-02-2009 01:49 PM
94FORDCHICK615
05-28-2008 12:42 PM
JimR1957
07-27-2006 09:45 PM
remmers
10-27-2003 02:19 PM
Quick Reply: Vapor Canister Vent Solenoid
