Help!!!
Old May 24, 2008 | 05:52 PM
94FORDCHICK615's Avatar
94FORDCHICK615
Help!!!
Ok i posted in the wrong spot! So here it goes again..
1994 ford explorer
Does anyone know where the intake vaccum hose would run to or from??
It has come off, but cant seem to find a dangling hose anywhere...
Any suggestions?? Have been successfull here before, fixed my girl 2 times from this site..
Thanks for any help in advance!
Old May 24, 2008 | 08:18 PM
ITFD's Avatar
ITFD
I have never been under the hood of a 94 but the hose could go to either the brake booster or to a vacuum dist tee
Old May 26, 2008 | 08:06 PM
fordtrucklover94's Avatar
fordtrucklover94
I think ITFD is right, it's been a while since I've looked under the hood of my buddies 94, but I'm pretty sure that it's over around that area, I know it is on my 98.
Old May 28, 2008 | 12:42 PM
matt2ts's Avatar
matt2ts
Check under the hood. On most models there is a sticker attached either to the hood or in front of the radiator that shows where the vacuum lines run for all the emissions. If the line is 1/4" diameter it would go to the brake booster on the firewall from the side of the intake plenum. If its smaller be sure and trace where the vacuum lines run into the plastic looms (split corrogated pipe looking things) Took me a while to find one I had broken.
hope this helps
Auburn56
18
Nov 8, 2020 06:23 PM
rojoraider
15
Jan 20, 2016 03:15 PM
Big Skier
Apr 10, 2011 12:19 AM
mybigredford
Aug 29, 2007 06:59 PM
