1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Cutting out
Old 07-24-2014, 02:16 PM
Redcows's Avatar
Redcows
Redcows is offline
Cutting out
I have a 07 f250 fx4 with 111000 miles on it. When it is loaded either by having a trailer on it or by it having to lug from a stop to get moving to back up a hill or if I stop to put it in 4x4 then it cuts out. If u knock it in neutral and give it gas it is fine but it lugs down and sputters out at Rpms of 1300 or less some of the time. It is a5.4 liter any ideas on what I need to change. I have ran injector cleaner through it at different times since it was new and I only run 91 octane
Old 07-25-2014, 07:01 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Welcome to FTE. I don't own a 5.4 truck, so I can't really comment on it. But I can give your thread a bump! Perhaps this thread should be moved to a different forum?
Old 07-25-2014, 08:02 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
Any codes on the motor? Check engine light?
When was the last time a fuel filter was changed on it and have you check the fuel pressure on it?
Old 07-26-2014, 08:29 AM
Redcows's Avatar
Redcows
Redcows is offline
No there is no check engine light on I'm not sure that I have ever changed the fuel filter with as many as I have it's hard to keep up. How would I go about checking the fuel pressure ?
Old 07-26-2014, 08:30 AM
Redcows's Avatar
Redcows
Redcows is offline
Um ok where should I move it to? Thanks a ton
Old 07-26-2014, 09:43 AM
Hotpocket's Avatar
Hotpocket
Hotpocket is offline
This is the best place for 5.4 questions...I would start with checking fuel pressure as well. You can rent one from autozone
Old 07-26-2014, 12:18 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Does it idle OK?
Old 07-26-2014, 02:03 PM
Redcows's Avatar
Redcows
Redcows is offline
Originally Posted by redford
Does it idle OK?
Yes it idels fine the only time it lugs is if it has to back up a little incline or is stopped n the mud or starting with a trailer on from idle to 12-1300 rpm it cuts out if i drop n neutral and gas it is fine but under a load until it gets to around 1500rpm it lugs and cuts out once it gets up n rpm it runs great like always plenty of power
Scott Johansen
02-20-2012 07:50 PM
rsstiegler
1997 - 2003 F150
10-21-2009 07:23 AM
newexplorer
10-31-2005 04:04 PM
ford5.8
25
12-08-2004 10:37 PM
Sleepy Paul
07-26-2003 02:25 PM
Quick Reply: Cutting out
